Headstud stuck in block (Diagram)
Old May 20, 2007 | 11:07 AM
guedo148's Avatar
Default Headstud stuck in block (Diagram)
I ordered a Timsert kit for my B18C1 because it had a stripped headbolt thread.so i thought i'd repaired it but the insert came out (i think i messed up with the kit). i thought i didn't use enough loctite so i used some JB Weld so the insert would stay in there for sure. Well it didn't and to make it more complicated, i put in a metal sleeve in the hole and that is now JB Welded to the sides of the hole. (yes i'm a retard, but i need help getting this fixed)
so now i can't take out my headstud because the Timesert insert is still screwed onto the headstud and the metal sleeve is stuck and won't let me take it out.
Here's a diagram for clarification:
So what do you all suggest i do? one of my friends said to take it to a machine shop and they'd cut the headstud and drill out everything, then fill the hole with aluminum, retap it, and it'd be good as new.
what do you guys think? any guesses?
Old May 20, 2007 | 01:50 PM
stumpyf4's Avatar
Default Re: Headstud stuck in block (guedo148)
Use some heat (propane torch) then try to unscrew it.
Old May 20, 2007 | 10:05 PM
guedo148's Avatar
Default Re: Headstud stuck in block (stumpyf4)
no the headstud and timesert are loose but i can't take them out because they hit that metal sleeve which is in there really tight.
Old May 21, 2007 | 06:43 AM
Flashmn's Avatar
Take it to a machine shop before you do any more damage. Next time follow the instructions of the kit.
Old May 21, 2007 | 07:01 AM
guedo148's Avatar
i did follow instructions word for word but the insert still came out. don't know what i did wrong
Old May 21, 2007 | 01:58 PM
hitekper4mance's Avatar
Default Re: (guedo148)
thats wierd. So, you are saying that the metal sleeve and the insert were JB welded but only one actually adhered? Thats just what you call bad luck. Sounds like something of mine. HAHA. Sorry. I say if it doesnt come "straight" out with some pounding, take it to the machine shop cause who knows how much more bad luck may happen. Good luck!!
Old May 21, 2007 | 02:26 PM
guedo148's Avatar
thanks. yeah i took it to a machine shop and they cleared it out.
now the next problem is fixing the thread. there was a helicoil installed in it before, which messed up. and that's why i think the timesert didn't work.
i think i need to use some Timesert Big-serts, which are specifically for repairing the threads a second time or after use of a helicoil. only problem is i don't know any shops around my area that have those. i'll call around tomorrow. any ideas?
Old May 21, 2007 | 03:44 PM
machine shop couldnt fill it or rethread it themselves??
Old May 21, 2007 | 04:12 PM
guedo148's Avatar
the one i went to couldn't. it's harder because it already had a helicoil. i'll call around tho.
Old May 21, 2007 | 07:02 PM
dpaton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guedo148 &raquo;</TD></TR><TR><TD CLASS="quote">the one i went to couldn't. it's harder because it already had a helicoil. i'll call around tho. </TD></TR></TABLE>
Timesert has special kits for helicoiled holes. I don't think they can do a headstud though...I don't think there's enough meat left in there to drill it out far enough for the larger timesert. Call them to check it out though.
Old May 22, 2007 | 04:41 AM
guedo148's Avatar
yeah they have those Big-Serts. But i don't wanna pay $410 for the kit.
i'll see if anyone can weld the hole shut with aluminum then just retap it.
Old May 22, 2007 | 05:38 AM
dpaton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guedo148 &raquo;</TD></TR><TR><TD CLASS="quote">yeah they have those Big-Serts. But i don't wanna pay $410 for the kit. </TD></TR></TABLE>
Might as well just buy a new block then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guedo148 &raquo;</TD></TR><TR><TD CLASS="quote">i'll see if anyone can weld the hole shut with aluminum then just retap it. </TD></TR></TABLE>
No one's going to be able to weld that hole, that far down in the block, with any kind of quality. It's just not done. If it was a surface weld, sure, but an inch and a half down, not a chance.
Old May 22, 2007 | 06:17 AM
Lubo_25's Avatar
Default Re: (dpaton)
what im curious about is how did that stud rip your threads out?? what lubricant did you use...and no youre not a retard even the best expletive up like the rest of us...
Old May 22, 2007 | 06:19 AM
guedo148's Avatar
Default Re: (Lubo_25)
well there was a helicoil in the hole before i put the timesert in. the helicoil was screwed up. i didn't know i need a big-sert kit to repair it and just bought the timesert kit used off ebay for pretty cheap.
Old May 22, 2007 | 07:57 AM
dpaton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guedo148 &raquo;</TD></TR><TR><TD CLASS="quote">well there was a helicoil in the hole before i put the timesert in. the helicoil was screwed up. i didn't know i need a big-sert kit to repair it and just bought the timesert kit used off ebay for pretty cheap. </TD></TR></TABLE>
Ahh...I see now.
Yeah, the threads are too F'd for anything but a big-sert or a new block. Like I said, TIGing that hole is somewhere between impossible and unimaginable.
Sorry man...them's the brakes.
Old May 22, 2007 | 08:50 AM
guedo148's Avatar
yeah.. oh well i'm starting to get used to my chronic bad luck with this engine.
if i don't find a bigsert kit i'll try to call ARP and get a bigger headstud that i can just tap the block and use that one.
i don't feel like getting a new block. if the block is messed up i'll just part it out and build a d-series turbo, something i should've done in the first place.
guedo148
Jul 7, 2007 02:19 PM
Turbo-Honda
Welding / Fabrication
Apr 7, 2006 08:29 PM
bigz187
Nov 28, 2005 12:53 PM
dunkd
Jun 30, 2004 12:25 AM
PSU-TEG
May 18, 2003 03:24 PM
