jdm b18c type r/gsr
i know that the jdm type r motors have b18c on the block and the gsr say the same thing. is there another way to tell if a bock is a type r block without taking the head off to see the pistons?
Code Displacement Power Torque Compression Bore Stroke Cam Design VTEC? OBD Production
<U>B18C1</U> 1797 170@7600 128@6200 10.0:1 81 87.2 dohc yes 1 or 2 1994-2001 Integra GSR
<U>B18C</U> Spec R 1797 210@8100 130@7600 11.0:1 81 87.2 dohc yes 2 1997-2001 Integra Type R (JDM)
they dont say samething... look for the codes on the block...
Modified by KidBluff718 at 10:00 AM 5/20/2007
search please. this is the 3rd or 4th thread in the last 2 weeks about this subject
https://honda-tech.com/zerothread?id=693766
https://honda-tech.com/zerothread?id=1262431
https://honda-tech.com/zerothread?id=1066346
https://honda-tech.com/zerothread?id=1199973
just a few
just a few
thanks alot. is see that there is alot of speculation and misinformation on this subject in those post. well mine has a 19xxxx under the B18C . and the tranny has the JHD LSD stamp and the head has the pr3 on it along with the p73 ecu and intake manifold. the only other thing i was wanting toknow is. i know the gsr and type r have alot of the same parts along with the block, because i see the block on the back says P72 and acouple of other components like the timing belt cover has P72 aswell.
o yea mine is supose to be a 96 spec-R but the ecu has a 98 spec ecu code on it, is that good or bad?
just wanting to know if that is all normal?
I have a b18c with pr3 on the head and the timing belt sprockets
I was wondering if the p73 ecu is the correct one for all JDM ITR or how to tell what year my engine is.
what kind of distributor cap do I need?
p73-003 and p73-a02 are the jdm-usdm codes for a 96-97 itr., the usdm 97 of course. p73-012 and 023 i'm not 100% on since both are 98+, i've heard 023 starts in 2000 but have never verified it. a03 is 98-99 and a04 is obd2b 00-01
jdmb18c-hatch
Nov 24, 2009 07:27 AM
rickkane
Jul 30, 2008 10:43 PM
