vtec pressure valve question
Old May 18, 2007 | 11:37 AM
b_serious's Avatar
Default vtec pressure valve question
i have a vafcII uberdata chipped p28 runnin my d16z6 with cam gear, cam, upgraded valvetrain.. im getting a CEL on redline whenever i redline it. it doesnt go away until i shut the car off and start it again. anyone know what cause this?
it is code 22 vtec pressure valve
Old May 18, 2007 | 11:43 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: vtec pressure valve question (b_serious)
Check your oil level before you do ANYTHING else - most common cause for code 22 is too low of an oil level for the VTEC pressure switch to pick up.
If the oil level is good, then it's time to worry about that V-AFC install!
Old May 18, 2007 | 12:05 PM
b_serious's Avatar
Default Re: vtec pressure valve question (B18C5-EH2)
when i got the car it was at the last mark ont he dipstick then i filled it to the top mark. it runs ok, and vafc confirms that vtec is kicking in where it should
Old May 18, 2007 | 12:14 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Why run a V-AFC with an Uberdata tune? I ditched my V-AFC when I went with Uberdata - it's redundant.
How long has the car had the V-AFC, and has it ran for a while with no check engine codes?
Old May 18, 2007 | 12:17 PM
1995Civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Why run a V-AFC with an Uberdata tune? I ditched my V-AFC when I went with Uberdata - it's redundant.
How long has the car had the V-AFC, and has it ran for a while with no check engine codes?</TD></TR></TABLE>
I was thinking the same thing.
If you have a chipped program, why run a hack?
Either way, listen to B18C5...he aint called the Civic forum legend for nothin!
Old May 18, 2007 | 12:20 PM
b_serious's Avatar
honestly.. i have no idea. it was all in the car when i bought it 2 days ago, i was just trading shells but i ended up throwing in cash with the trade and keeping the engine. its a 92 si hatch, the guy wont respond to my emails about what the ecu is chipped for and if its ever been tunes with the vafc
Old May 18, 2007 | 12:23 PM
B18C5-EH2's Avatar
Former Moderator
Loved
I would uninstall the V-AFC and solder any of the wires that were cut, then have the ECU rechipped again by a local reputable Uberdata or Crome tuner and start fresh.
Most V-AFCs are not installed right, and over time even the ones that were installed right take a crap anyways. You can always sell it to someone who really wants the "awesome digital read-out" so they can mount it on the dashboard for all to see.
I never had problems with my V-AFc, but it was installed nicely with soldered wires, etc. I unsinstalled it because a guy wanted to buy it, and frienbd installed and tuned Uberdata on a dyno for $100.00 - I couldn't pass it up.
With Uberdata or Crome set-up right you can also have a check engine shift light, drag launch, etc. It's definately better than a piggy back like a V-AFC that's tapped into the wiring, etc.
Just my 2 cents.
Old May 18, 2007 | 12:26 PM
b_serious's Avatar
sounds good, i think this vafc has the jumper harness though so i guess ill just unplug it and sell it for a few hundred and put that money toward another tune
although i dont know whats exactly done to the engine, or the specs of the parts he told me in person but i totally forgot
Old May 18, 2007 | 12:29 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Jumper harness? You sure it's not tapped into any wires? They all have a harness that unplugs from the actual display/box, but it's usually hacked into the chassis harness at the ECU - I'd completely uninstall it and resotre the factory wiring to eliminate the actual wiring as a source of your code 22.
Old May 18, 2007 | 12:43 PM
b_serious's Avatar
ill uninstall it tonight and see if that effects it, should i change the oil too?
Old May 18, 2007 | 12:46 PM
blaze_125's Avatar
how's the oil screen/filter on the valve?
Old May 18, 2007 | 12:47 PM
b_serious's Avatar
Default Re: (blaze_125)
i dont know i've never had a vtec engine, only ls/ls turbo's never messed with vtec how do i take it apart to see the screen? or clean it?
Old May 18, 2007 | 06:38 PM
b_serious's Avatar
how do i clean the vtec screen anyone know?
Old May 23, 2007 | 09:44 PM
mister_ej1's Avatar
Default Re: (b_serious)
i am having the same problem only VTEC kicks out in 3rd gear or i guess when i go through a gear or two in VTEC....my first VTEC motor too....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_serious &raquo;</TD></TR><TR><TD CLASS="quote">how do i clean the vtec screen anyone know?</TD></TR></TABLE>
if this would help, someone please tell
Old May 24, 2007 | 12:46 PM
blaze_125's Avatar
http://media.honda.co.uk/car/o...4.pdf
http://www.ef-honda.com/ben/OPSnVTECsol.jpg
Old May 25, 2007 | 07:04 PM
b_serious's Avatar
Default Re: (mister_ej1)
exactly its in my 3rd gear when i get the CEL weird
Old May 26, 2007 | 12:44 PM
mister_ej1's Avatar
i talked to someone yesterday and he said to go ahead and get new gaskets for the vtec solenoid and clean the filter and try that....so i ordered the gaskets today but theyll be here thursday.....hoping that works and i dont have to buy another solenoid
Old May 26, 2007 | 02:15 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/zerothread?id=1812135
Old May 29, 2007 | 12:10 PM
mister_ej1's Avatar
Default Re: vtec pressure valve question (HondaPartsHero)
did you ever find out what was wrong
Old May 29, 2007 | 01:39 PM
b_serious's Avatar
Default Re: vtec pressure valve question (mister_ej1)
not yet i just rewired the engine did a bit of a tuck, re-did the timing i havn't tested it out yet though ill post up tonight my results
SkIp_Civic_Ek6
10
Jun 11, 2006 05:11 PM
lastlude2k1se
Nov 3, 2005 01:34 PM
92b16vx
Oct 25, 2003 02:07 AM
zCivic
Aug 20, 2003 09:01 AM
Incognito
Sep 13, 2002 01:32 PM
