which turbo is best?
Old May 18, 2007 | 07:14 AM
egsnail16's Avatar
Default which turbo is best?
I have a JDM b16a and i need to make sure the turbo i buy is a great one. One person said the T3/T4 turbo would be almost perfect for my car! I drive a 95 eg hb. Is garrett, better thant turbonetics? What would be a great setup to go with? thanks
Old May 18, 2007 | 07:24 AM
mightymaxgst's Avatar
turbonetics all day if u got the money for it....what size t3/t4 u trying to go with? and how much power u trying to make?
Old May 18, 2007 | 08:33 AM
Syndacate's Avatar
This question is absolutely impossible to answer.
Different turbos are good for different applications. If you floor it to the redline everywhere, a larger turbo might be better, if you tend to shift around 3k unless it's the occasional redline pounding you'd want it to spool early so you'd get a smaller one..
Without telling us a few things it's impossible to answer:
A) How is ur car setup? Track only car? Weekend driver? Daily driver?
B) What setup you running? Just a stock B16?
C) How much power are you trying to make?
D) Where do you generally shift at - how hard on it are you (generally)
Old May 18, 2007 | 08:44 AM
egsnail16's Avatar
Default Re: (Syndacate)
well right now this is the state my car is in: Toda cam gears, ITR tranny, stock head, stock bottom end, dyno tuned with B&m adjustible fuel regulator. stock fuel rail, skunk2 intake manifold, stock throttle body, 8mm spark plug wires. it is my daily driver. i want around 400whp give or take some, i know it would be at that with stock internals but when i do infact get internals i want to be around 400whp. Well at the track i sometimes full throttle ****, but on the street generally around 8000rpm right before redline. I do get on it some but i dont abuse it.
Old May 18, 2007 | 08:45 AM
egsnail16's Avatar
Default Re: (mightymaxgst)
around 400, but since i have stock internals one place can get me to around 340whp
Old May 18, 2007 | 08:56 AM
lucky4586's Avatar
Default Re: (egsnail16)
how much do you want to spend? are you looking for a kit or you building a kit maybe yourself. 400whp on 93 or race gas. It sounds like you want low end power and the best then for that is a small turbo that spools hell fast. ball bearing turbo it going to be the best, so look for that. gt30 "kinda big turbo" turbo would be pretty good for a bad *** turbo but you would really need to go with a 1.8 or 2.0l and 340whp is no going to be running long a stock block. Again i would stroke the 1.6 to 1.9 or go with a 1.8/2.0l build block...you can use gsr or do a ls/vte both have been done alotbefore, You also need the fuel system to handle the power im guessing something like 680cc or so. I would say on a 1.6 stock block, 225-250whp is safe. But there are so many factors you should look at. and the big question of Money, money money how much do you want to put in to it.
Oh im sure you know this just want to make sure... haveing a bigger engine will help the spool up alot and picking the right turbo for the app. There is no repalcement for displacement!
Old May 18, 2007 | 09:40 AM
BlackoutVTi's Avatar
Default Re: (lucky4586)
Turbonetics specializes in higher boost, competition turbo applications, and I've heard good things about their performance and quality. Since you're looking for around 400HP (omg ), I'd say just look into Turbonetics.
Old May 18, 2007 | 11:13 AM
Team RS2's Avatar
Default Re: (BlackoutVTi)
post your dyno sheet and if ill reccommend a turbo to widden out your power band
Old May 18, 2007 | 12:04 PM
VTECth1s's Avatar
Either company will get you great results, Turbonetics manufacture larger size turbos iirc. Great for the high HP goals, I'd say build your internals prior to installing the turbo kit, better safe then sorry, especially since you mentioned reving near redline. Or just get the turbo setup you want, and get it tuned at low boost, till you can afford internals, then up the boost and retune.
Old May 24, 2007 | 01:32 PM
egsnail16's Avatar
Default Re: (VTECth1s)
Im not building my internals first. im buying my turbo setup, and im piecing it together. i will run at low boost untill i do infact build my turbo but i was just asking which turbo company will be better, because im getting a t3/t4 turbo.
Old May 24, 2007 | 01:47 PM
SkertySkerty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsnail16 &raquo;</TD></TR><TR><TD CLASS="quote">Im not building my internals first. im buying my turbo setup, and im piecing it together. i will run at low boost untill i do infact build my turbo but i was just asking which turbo company will be better, because im getting a t3/t4 turbo.</TD></TR></TABLE>
you keep saying you want a t3/t4 turbo well needless to say there are many different size t3/t4's on the market you have 51 trims up to 60-1's good for 200-600hp so i mean you say you want a t3/t4 yet you have no idea what your talking about go do some research hears a good sight for you
http://www.atpturbo.com/Mercha...e=GRT
have a little fun thats the garrett store for ya
now just to let you know my friend has a fully built 2.0 ltr gsr with a full race gt30r kit and he only makes 460 hp @ 28 psi and a gt30r isnt a small turbo but its more efficient than its big brother the t3/t4 57 trim and 60-1 trim levels because its a ball bearing turbo and the t3/t4 57 trim isnt so needless to say it make the same hp and it spools up a lot faster now you can go with a twin scroll gt35r which spools up at just at 4k rpm and make 600 hp or you can go with a twin scroll gt42r and push 1k hp its on u but build the car before you think about a turbo
Old May 24, 2007 | 02:45 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (SkertySkerty)
People who want a particular HP number are, generally, utterly ignorant to the benefits of turbocharging a car. The only number that matters is your E.T. Peak HP is the huge, virgin **** of the Honda world: it seems good, but it doesn't matter much.
Set an E.T. goal and build from there. First, though, do enough research that I don't hate you when you post
Old May 27, 2007 | 09:58 AM
egsnail16's Avatar
Default Re: (Archidictus)
Haha, your making your self look like and idiot. I know what trim i want, thats not the question i asked, i simply asked who makes the better turbo, turbonetics or garrett! so before you start getting all cocky thinking you know the world read a little bit closer. and since you didnt even answer the question i was asking why did you even post? If you have nothing to say to the original question dont wast my time!
Old May 27, 2007 | 10:04 AM
Otherguy's Avatar
NASIOC.com
egsnail16,
Just on a side note... Watch who your talking to
Old May 31, 2007 | 04:07 PM
Garretthonda95's Avatar
hey can you helpme, i have a d16z6 civic and i have a garrett turbo, its a GT17, im wondering if thats good for 300hp,because i saw a grapg that had displacement and the turbo size and the gt17 was right at 1.6 liters but then i read somewhere that it can go to 220hp or somthing, can you help me out
Old May 31, 2007 | 08:08 PM
Default Re: (Garretthonda95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garretthonda95 &raquo;</TD></TR><TR><TD CLASS="quote">hey can you helpme, i have a d16z6 civic and i have a garrett turbo, its a GT17, im wondering if thats good for 300hp,because i saw a grapg that had displacement and the turbo size and the gt17 was right at 1.6 liters but then i read somewhere that it can go to 220hp or somthing, can you help me out </TD></TR></TABLE>
look up at my other post click on the ling it tells you everything about garretts
Old May 31, 2007 | 08:20 PM
germanegturbo's Avatar
Default Re: which turbo is best? (egsnail16)
well i had a garrett t3/t4 45 trim on a stock b16 and it ripped....spooled emideatly and never hade ne problems..actually selling hte turbo kit for a b 16 that used to be in my eg
Old May 31, 2007 | 10:09 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
definately get a ball bearing turbo. garret makes a gt3076r, it will spool up quicker than an average size t3/t4 and make more power at the same psi.
im already replacing my turbonetics t3/t4 for a gt30.
airwalk07143
Sep 19, 2009 09:10 AM
broketuner-Sol_Si
Jan 15, 2006 09:00 AM
DC2 BoZz
Sep 25, 2004 07:44 PM
riceburnah
Jul 14, 2004 08:02 PM
TriK
Jan 30, 2003 11:26 AM
