questions about tps and the effects it can cause!!! please help!
Old May 18, 2007 | 06:59 AM
LS AzZkIkr's Avatar
Default questions about tps and the effects it can cause!!! please help!
i have been trying to set my tps to the correct settings that i found on this site and it will only go down to 4.699 WOT and .5... ! i have taken the rivets out and replaced it with screws for adjustibility. someone please help!
Old May 18, 2007 | 07:03 AM
EE_Chris's Avatar
Default Re: questions about tps and the effects it can cause!!! please help! (LS AzZkIkr)
You adjust the TPS for only the idle, which should be <.5v. At WOT, it should spit out ~4.5v, but if it doesn't, tough ****. To adjust the TPS to make the WOT reading higher/lower means you directly effect the setting at idle, which you don't want to do.
Throwback23
May 4, 2010 09:33 PM
gimmick
Oct 23, 2008 05:12 PM
sCeRaXn
Nov 9, 2003 07:08 PM
cirionrc
Apr 27, 2002 10:47 AM
