neu ecu upgrade for 15psi- 1 bar ladedruck
Old May 18, 2007 | 01:17 AM
TURKISHFORCE's Avatar
Default neu ecu upgrade for 15psi- 1 bar ladedruck help
hi, i have problems wit high boost psi over 15 psi.
engine jerk ELT with high loading pressure(misfiring??ignition??)
we used this map sensor for high psi ..
http://www.g-laderseite.de/esh...d=124
?????is the (zündspuhle) spark to low ignite spuhle??
http://images.google.de/imgres...a%3DN
Old May 18, 2007 | 02:14 AM
Semnos's Avatar
Default Re: neu ecu upgrade for 15psi- 1 bar ladedruck help (TURKISHFORCE)
Try gapping your sparkplugs
Old May 18, 2007 | 05:21 AM
Default Re: neu ecu upgrade for 15psi- 1 bar ladedruck help (Semnos)
wath is the best sparkplugs for my turbo civic ef9 (ee9)b16a1 vtec 1,6l benzin model 90.???
i have ride now orginal ngk bkr6e-n11?
Old May 18, 2007 | 07:57 AM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURKISHFORCE &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.g-laderseite.de/esh...d=124</TD></TR></TABLE>
38 EUROs...wow, I can get those shiped to me for 1/3 that! I'm in the wrong business. But thats the motorola/freescale sensor, they are very accurate.
You might want to go a step colder, heat range 7 (ngk bkr7e-n11, if thats a working number). Mostly everyone on HT will recomend NGK for boost. Gap them to .028" (.71mm), then drop down more if it still has issues.
sakasaku
Oct 28, 2010 10:51 AM
4dek
Jul 3, 2008 08:31 PM
ej1252
Nov 3, 2007 07:40 PM
NOSED_CRX_VTEC
Sep 27, 2003 05:47 AM
Propulsion
May 13, 2003 12:59 AM
