recalibrate TPS??????anyone?
Old May 16, 2007 | 08:25 PM
h8ted ek's Avatar
Default recalibrate TPS??????anyone?
tried searching only found one thread.
I had put in a new TPS since the one before on it was fawked.
anyways, someone i came across said i should recalibrate it because it looked off and i do feel a difference maybe in my head with performance and the idling
I do have a volt meter but how should i approach it?
any info would happily appreciated
Old May 17, 2007 | 11:03 AM
h8ted ek's Avatar
Default Re: recalibrate TPS??????anyone? (h8ted ek)
anyone?
how can tps affect my performance if its not recalibrated correctly? i do know that i used to pull hard when it was working
Old May 17, 2007 | 05:29 PM
builthatch's Avatar
MiG-21 superfan
you want it to be .5Vish at idle and 4.5V at full throttle. you can set this by rotating it until you get the settings you want; at that point you tighten it down and check to see if the settings held.
Throwback23
May 4, 2010 09:33 PM
o'malley_808
Aug 6, 2009 10:24 AM
LS AzZkIkr
May 18, 2007 07:03 AM
Sketch_hs
21
Jun 15, 2005 01:56 PM
Shft@9GSR
Nov 15, 2002 11:21 AM
