can bad water pump cause therostat not to open
Old May 15, 2007 | 02:15 AM
lv6l's Avatar
Default can bad water pump cause therostat not to open
92 honda civic vx. car doesn't really overheat. just needle goes a little above the middle point. i flush the system, i had a used thermostat off my old cx motor that i know works; i put that on the vx. the fan doesn't come on, i'll double check the wires to see if its wire correctly(bought car off some dude that ghetto wire everything in the car) lower radiator hose is cool to the touch and top is hot. so i'm guessing the fan is not turning on because the thermostat is not opening up but my question is can a bad water pump cause the thermostat not to open. thanks in advance.
Old May 15, 2007 | 10:42 AM
lv6l's Avatar
bump
Old May 16, 2007 | 02:21 AM
lv6l's Avatar
anyone?
Old May 16, 2007 | 03:33 AM
mikeycivic's Avatar
Default Re: (lv6l)
if I had to guess I would say no, that the water pump has nothing to do with the thermostat not opening unless you had no coolant. Try putting in a new thermostat and see if that helps, also did you burp the system, you could have air in the system which def. will cause issues with thermostat not opening
Old May 16, 2007 | 03:45 AM
blackKready's Avatar
Default Re: (mikeycivic)
just put a thermo in it dude.
Old May 16, 2007 | 03:59 PM
lv6l's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">if I had to guess I would say no, that the water pump has nothing to do with the thermostat not opening unless you had no coolant. Try putting in a new thermostat and see if that helps, also did you burp the system, you could have air in the system which def. will cause issues with thermostat not opening</TD></TR></TABLE>
i pour in coolant, open the nipple to bleed, turn on motor, i see a lot of bubbles coming out of the bleeding nut for a while. how long should it take to fully bleed out all the bubbles normally? and is the radiator cap suppose to be on or off when doing this. thanks.
Old May 16, 2007 | 04:42 PM
Default Re: (lv6l)
you really dont need that bleeder screw. take the rad cap off and leave it off when engine is cold , start the car and let it fully warm up with rad cap off and keep topping it up the whole time. than put it back on , done.
HiChanDC2R
Aug 15, 2010 05:15 PM
nonvtec92
14
Nov 28, 2008 04:50 PM
WhiteOnRice
11
Nov 30, 2007 12:59 PM
sin city eg6
Feb 22, 2007 08:37 AM
christiian
18
Jul 16, 2006 12:03 AM
