new headers and my car sounds like crap
Old May 14, 2007 | 02:26 PM
leroyb's Avatar
Default new headers and my car sounds like crap
well i just instaled some headers in my 96ex with a d15b the problem i'm noticing is that the car sounds like crap at low rpms i think its coming from the cat but i'm not sure thanks for the help
Old May 14, 2007 | 02:28 PM
sohctodohc's Avatar
Default Re: new headers and my car sounds like crap (leroyb)
what does it sound like??? a leak or what??? by the way the usdm d15s only came with one header
Old May 14, 2007 | 02:39 PM
leroyb's Avatar
o yea its just a habbit but kinda like a leak i guess
Old May 14, 2007 | 02:55 PM
leroyb's Avatar
bump for help
Old May 14, 2007 | 02:56 PM
Ghetto Civic HX's Avatar
I love to drive
Did you install a donut gasket between the header and the cat?
Get under the car while it's running and feel around the collector. If there's a leak, you'll be able to feel it.
ke98248's Avatar
Make sure the gaskets are sealing, and that the 02 sensor plugs (if you're not using them all) have anti-seize on them and are torqued down good and hard.
Old May 14, 2007 | 03:05 PM
leroyb's Avatar
yea it has all that are the bolts with the springs suppost to ba all compressed??????
Old May 14, 2007 | 03:06 PM
ke98248's Avatar
Check your Chilton/Helms manual for the torque specs..
I think they are 44lbs & 22lbs, but not sure for which bolts, so I'd look up the torque specs.
Old May 14, 2007 | 03:10 PM
leroyb's Avatar
and is every thing suppost to fit in oem because i hade to use a crow bar to get the bolts on
Old May 14, 2007 | 03:13 PM
ke98248's Avatar
I didn't with my MG header + catback exhaust, but I guess fitment is diff. for each brand (by a lil bit)
Old May 14, 2007 | 03:14 PM
EJ1_Ex's Avatar
post a vid on how is sounds like...
Old May 14, 2007 | 03:20 PM
bleedblue94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leroyb &raquo;</TD></TR><TR><TD CLASS="quote">and is every thing suppost to fit in oem because i hade to use a crow bar to get the bolts on</TD></TR></TABLE>
umm im allittle scared to know how you had to use a crow bar for this install
o2sI
Oct 27, 2004 09:54 AM
tbud454
13
Jan 19, 2004 12:29 AM
fergy016
Sep 29, 2002 11:08 PM
yaksplat
Aug 28, 2001 10:24 AM
MintyDip
Aug 2, 2001 06:52 PM
