header install
Old Aug 28, 2001 | 09:42 AM
yaksplat's Avatar
Default header install
i'm about to put on a DC SS 4-2-1 header
I already bought new gaskets from the dealer
is there anything else i should do or plan for?
Old Aug 28, 2001 | 09:58 AM
Evil DOHC's Avatar
Default Re: header install (yaksplat)
Get some WD-40 forthose bolts. Don't take out the radiator fans like everybody tells you to do. You do need to take out the black plastic splash shield thats attached to your bumper on the buttom of the car. Good Luck.
EVIL
Old Aug 28, 2001 | 10:00 AM
yaksplat's Avatar
Default Re: header install (Evil GS-R)
i've been spraying aero-kroil on them every day for the past week
nothing beats it
it get's into spaces down to the millionth of an inch
the stuff is amazing
Old Aug 28, 2001 | 10:10 AM
IgniteTeg's Avatar
Try not to bolt it too much or you will break it. Broken mine, my friend broke his geez those thing are so sensitive. Good luck.
Old Aug 28, 2001 | 10:11 AM
yaksplat's Avatar
Default Re: header install (IgniteTeg)
did you go by torque specs in the factory manual?
Old Aug 28, 2001 | 10:20 AM
Evil DOHC's Avatar
Always tighten the manifold from the inside out. Meaning the inside bolts to the outer bolts. I didn't torque them, there is no need. It will seal good with a stock gasket.
EVIL
Old Aug 28, 2001 | 10:24 AM
samagon's Avatar
my shadetree mechanics manual says to "keep turnin' those suckers till your fingers turn red"
bsampson
Jan 24, 2009 11:58 PM
BeBe
May 4, 2004 08:39 PM
RacerXintegra2k
Dec 28, 2002 11:59 AM
redGSRguy
Aug 3, 2002 09:47 PM
pstreck
Jul 31, 2001 08:52 PM
