Tranny seems to be slipping/99 ex
Old May 14, 2007 | 06:44 AM
creepy116's Avatar
Default Tranny seems to be slipping/99 ex
hi i have a 99 civic coupe and my tranny seems to be slipping out. when i am in any gear and i accelerate my shifter moves back and forth and also when i am in 2nd gear and make a turn it slips out and grinds. any help? thank you
Old May 14, 2007 | 06:47 AM
JDM_SOHC's Avatar
Default Re: Tranny seems to be slipping/99 ex (creepy116)
make sure ur axles arent popping out... jack ur front end up and turn ur wheel all the way left and all the way right... see if they're coming out of the transmission at all... that happened to me a while ago and i thought it was my tranny but it was one of my axles that was all fukced up..
Old May 14, 2007 | 06:51 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Tranny seems to be slipping/99 ex (JDM_SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote">make sure ur axles arent popping out... jack ur front end up and turn ur wheel all the way left and all the way right... see if they're coming out of the transmission at all... that happened to me a while ago and i thought it was my tranny but it was one of my axles that was all fukced up..</TD></TR></TABLE>
well the axle wont physically make the shifter come out of gear. if that is what's happening. The OP, is the shifter coming out of position? It's supposed to move a little back and forth when you accelerate/decelerate, thats normal.
The OP's situation usually happens when there is a low fluid level in the trans. Or the wrong fluid. Drain out your old, fill in some new HONDA MTF. Hope that it fixes it. If not, then check shift linkages, etc. Make sure your shifter rods arent bent. Make sure your motor mounts arent worn, and making the engine and trans move more than they should and pulling the trans out of gear...although this is probably not too likely.
If the fluid method doesnt work...then you wasted $10 and need a new trans.
Old May 14, 2007 | 08:07 AM
95ProjectEJ1's Avatar
Default Re: Tranny seems to be slipping/99 ex (B serious)
I was going to say the motor mounts too...
1bar_ek
May 18, 2008 04:44 PM
garagetunedInc
Feb 13, 2008 09:44 PM
gsrHB
Sep 20, 2005 07:50 PM
2manycars2choose
Apr 26, 2005 11:45 AM
Propulsion
Sep 22, 2003 06:23 AM
