Any one know how to use a tapping set. I am trying to tap my EGR ports.
Old May 12, 2007 | 07:59 AM
JBirch_97Prelude's Avatar
Default Any one know how to use a tapping set. I am trying to tap my EGR ports.
I was doing great until I opened the box. Now I have no idea what to do.
Old May 12, 2007 | 08:20 AM
BB6racer's Avatar
tap sets are for making threads, which you shouldn't need to do. you're supposed to drill a hole in the plugs with a drill and then use a slide hammer to pull out of the manifold.
but to answer your question i think you just attach whatever tap you plan on using to a hand wrench and slowly turn the bit to create the threads.
Old May 12, 2007 | 09:15 AM
Default Re: (BB6racer)
The slide hammer they sold me is way to big. I am going to try and find a smaller version.
Old May 12, 2007 | 09:24 AM
mgags7's Avatar
In general, to tap a hole, you first drill it out to the size just smaller than the threads, then you lube the tap up, and screw it in slowly, blowing out the metal shavings as you go....
What is it you guys are doing to the egr that requires a slide hammer?
Old May 12, 2007 | 10:57 AM
kulrevon's Avatar
Default Re: (mgags7)
cmon matt you never cleaned your egr ports tisk tisk.
I have the pdf if you want to take a look.
for the ports you have to pull out the plugs that are in each runner. so you can clean out all the carbon stuck in there.
Old May 12, 2007 | 11:15 AM
mgags7's Avatar
oh
whatever
I don't really bother with that crayp.
Old May 12, 2007 | 12:01 PM
Well I knock the plugs into the ports. Now I think I just destroyed my intake!
Old May 12, 2007 | 02:58 PM
BlownH23a
Guest
Posts: n/a
gj, u get a gold star....just pull the intake mani off and do it that way...or, you could have just sea foamed your intake..but that would have been too easy huh.
Old May 12, 2007 | 07:25 PM
Default Re: (BlownH23a)
Did that and it did not help. The original Engine had 142,000+ miles on it and there is just to much build up.
94preludeguy
Jun 2, 2010 07:57 AM
KaoSyN
Mar 31, 2008 09:17 PM
Teglessb18
Jan 3, 2008 08:26 AM
lv6l
11
Oct 18, 2005 07:08 PM
AutoLab
Welding / Fabrication
Oct 11, 2004 10:20 AM
