Hole saws...
Old Oct 9, 2004 | 08:13 PM
AutoLab's Avatar
Default Hole saws...
Quick question. What brand hole saws are you guys using to punch holes in manifolds for the wg? For the past few years we've just used the ones from Home Depot and they are only good for a manifold then are dead. Since our volume of fabrication has gone through the roof in the past few months we need to find a faster way of doing this.
Any ideas or comments are welcome, thanks
-bill
Old Oct 10, 2004 | 01:12 AM
c jackson's Avatar
threes
Default Re: Hole saws... (AutoLab)
lennox
Old Oct 10, 2004 | 06:26 AM
matt_sb2000's Avatar
Default Re: Hole saws... (c jackson)
If you have a mill stop using hole saws.
If you have to use hole saws, slow them waaaaaay down. Like 150 rpm, and alot of rapid tap.
Old Oct 10, 2004 | 07:20 AM
Tinker219's Avatar
Default Re: Hole saws... (matt_sb2000)
https://honda-tech.com/zerothread?id=1013754
and you can do alot more w/it! Just make sure you stuff the hell out of the backside of the hole, and clean up around the cut, otherwise welding is a chore(and weak).
Old Oct 10, 2004 | 08:19 AM
cjb80's Avatar
Default Re: Hole saws... (Tinker219)
Pull the tungsten out of your gun and turn the amps up to 150 and use your welder to cut a hole Then just start grinding away
Chris
Old Oct 11, 2004 | 07:55 AM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_sb2000 &raquo;</TD></TR><TR><TD CLASS="quote">
If you have to use hole saws, slow them waaaaaay down. Like 150 rpm, and alot of rapid tap.</TD></TR></TABLE>
Old Oct 11, 2004 | 10:20 AM
pete98m3's Avatar
gave up on that **** a long time ago.
plasma cutter
i have a miller 30amp unit and i've never encountered anything it can't cut cleanly while doing automotive fab.
That is a SCREAMIN deal though ^
KtHaNxBai
May 25, 2012 07:32 AM
DrGrEeNtHuMb
Welding / Fabrication
13
Jun 4, 2008 07:57 PM
*Boostwerks*
47
Jul 2, 2006 05:53 AM
mbpowner
Honda Motorcycles
May 24, 2006 09:15 PM
JonnySBeee...
24
Feb 9, 2005 09:24 PM
