how hard is to make a down pipe
Old May 11, 2007 | 07:42 PM
h22_crx's Avatar
Default how hard is to make a down pipe
how hard is it to make a turbo down pipe 3"
Old May 11, 2007 | 07:49 PM
Jared's Avatar
damn hard with a gt45r in a yugo......
Old May 11, 2007 | 08:21 PM
Top Ramen's Avatar
Default Re: how hard is to make a down pipe (h22_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22_crx &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to make a turbo down pipe 3"</TD></TR></TABLE>
What are you really asking? Do you just want to know how hard it is to weld some 3" bends together or are you asking a fitment/clearance question?
Ask a better question = get a better answer.
Old May 12, 2007 | 03:49 AM
LordAphotic's Avatar
ahaha it really depends who you ask
but to make a downpipe isnt that hard... with the right tools.... you need a good method of cutting angles accurately like a bandsaw.... a chopsaw more than likely will be a headache but its doable... next you need to know how to weld.. tac the segments youve cut so you can see how it all fits before you completely weld it. also tac on flanges to make sure they are flush with their maiting surfaces...make adjustments where needed. weld completely around. grind the flanges with a table grinder or mill them down cause unless your using like a 1/2 inch flange more than likely your gona warp it on your first down pipe.... but just like with most things... the first time isnt that easy but the following times get progressively easier.
Old May 12, 2007 | 07:02 AM
ManBearPig4silly's Avatar
Your question is waaaaay to general.
what car? what turbo? what type of manifold? what material? what welding method? what is your welding/fabrication skill level in your own opinion?
answer those and you will get about 25 good answers to your question.
Old May 13, 2007 | 04:02 AM
m R g S r's Avatar
fkin hard man dont doo itttt!!!!
Old May 13, 2007 | 05:06 PM
c-techracing's Avatar
Default Re: how hard is to make a down pipe (m R g S r)
1st time. very expensive... by the 10 th time.... pretty easy.....
especially when you have the right tools.... lift, band saw, four hands.
Old May 13, 2007 | 07:01 PM
h22_crx's Avatar
Default Re: how hard is to make a down pipe (c-techracing)
i am not going to be doing it my dad is he builds airplanes
Old May 13, 2007 | 07:22 PM
bigTom's Avatar
I think is pretty damn easy! It comes down to if you know how to do it. It's pretty hard if you've never done one before. Think it through before u do anything. Having a plan will make it much easier.
LukieLuc
Dec 3, 2007 07:22 AM
GeeGee
Welding / Fabrication
May 11, 2007 06:35 PM
denske
10
Jan 22, 2006 03:36 PM
GForceInteg
Mar 30, 2005 02:01 PM
Kwuaymaikrup
Feb 16, 2005 02:46 PM
