Some input on what to do with the block?
Old May 11, 2007 | 02:30 PM
ek9tl's Avatar
Default Some input on what to do with the block?
Hey guys, i gotta type r motor and im thinking of sending the block off to the machine shop since it throws out alot of smoke. I know its the piston rings but i want to basically rebuild the block for turbo. I was wondering if someone can help me with a run down on what's the best way to start with sending it to the shop. Im just basically looking for info such as sleeving, bore, pistons, rods, etc. What compression rate should i look at since im going turbo, and brands for the internals? What should i do when i take the block to the machince shop. Im kind of a noob so please take it easy on me. Thanks for all input guys. Its kindly appreciated.
Old May 11, 2007 | 02:38 PM
SkertySkerty's Avatar
Benson sleeves 84mm bore wiseco 84mm 9:1cr superduper pistons find some good rods have fun stock crank can hold 600hp just get it blanced
Old May 11, 2007 | 02:50 PM
ek9tl's Avatar
Default Re: (SkertySkerty)
cool that wudd help a lil but, im tryin to get a run down of everything that i shuudd either keep or change. Thanks man
Sean EgHatch909
Aug 15, 2012 05:11 PM
spindler1
May 10, 2009 10:02 PM
Idiotboy
Oct 5, 2007 04:11 PM
ge_itr
Jan 8, 2007 09:37 AM
jdm'dc2sc61
Apr 9, 2005 02:13 PM
