Wont idle for some reason...
Old May 11, 2007 | 01:39 PM
jdm_DC2R's Avatar
Default Wont idle for some reason...
As topic states...my itr wont idle by itself. it starts fine, no hesitation, but as soon as i let the foot off the gas..it just dies, whether im driving or standing still. I checked the connections in the engine bay..and i havent spotted anything weird...and theres no check engine light on either.
Its a 96 spec with the original motor.
thanks in advance
Old May 11, 2007 | 03:54 PM
migs's Avatar
Default Re: Wont idle for some reason... (jdm_DC2R)
Last time I had a problem like this, it turned out that I had bad rings. Rings were bad so it couldnt hold compression. Do a compression check to get things started off.
Old May 11, 2007 | 04:08 PM
jdm_DC2R's Avatar
Default Re: Wont idle for some reason... (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Last time I had a problem like this, it turned out that I had bad rings. Rings were bad so it couldnt hold compression. Do a compression check to get things started off.</TD></TR></TABLE>
sounds scary...since i just had the motor rebuild 1000+kms ago. If it were rings..wouldnt the car run like crap overall too? cause in this case it doesnt.. drives fine, no problems at all, it just wont hold an idle..
Old May 11, 2007 | 04:39 PM
neo_'s Avatar
Check all your grounds (Tranny, Thermostat, Valve Cover).
Old May 11, 2007 | 06:15 PM
itr1244's Avatar
Default Re: Wont idle for some reason... (neo_)
check idle screw
Old May 12, 2007 | 06:54 AM
jdm_DC2R's Avatar
so far everything u guys said checked out ok, im leaning towards the idle air control valve...ill trouble shoot it now and see wat happens..
Old May 12, 2007 | 07:29 AM
neo_'s Avatar
Default Re: (jdm_DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_DC2R &raquo;</TD></TR><TR><TD CLASS="quote"> im leaning towards the idle air control valve</TD></TR></TABLE>
If it is your IACV, your car just won't idle properly. It won't shut off.
Old May 12, 2007 | 11:23 AM
jdm_DC2R's Avatar
Default Re: (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">
If it is your IACV, your car just won't idle properly. It won't shut off. </TD></TR></TABLE>
Wrong.
i just got another IACV, works perfect again, thats all that was. So anyone out there with the same problem, remember to check this valve first thing.
Old May 12, 2007 | 11:52 AM
itr1244's Avatar
Wrong.
i just got another IACV, works perfect again, thats all that was. So anyone out there with the same problem, remember to check this valve first thing.</TD></TR></TABLE>
how much did that part run you?
Old May 12, 2007 | 12:06 PM
jdm_DC2R's Avatar
Default Re: (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">
how much did that part run you?</TD></TR></TABLE>
$0.00 , i went back to the place i went to get my motor rebuilt (Point Zero), and they replaced it with another one they had there, so its not brand new, but it does the job for now.
Old May 12, 2007 | 02:05 PM
itr1244's Avatar
damn.. you got lucky
Old Aug 19, 2010 | 11:48 AM
rsx202002's Avatar
I'm having this problem too now. I cleaned out the throttle body and injectors. Was good for a couple weeks but now when I come to a stop the car just stalls out most of the time. Going to buy another IACV and see what happens.
andreasbrwn
Aug 30, 2009 05:25 PM
#1rudebwoy
Jul 25, 2009 01:30 AM
GSE980
Aug 12, 2006 04:02 PM
drewcandraw
11
Jun 5, 2005 12:21 AM
311
Dec 14, 2002 12:18 PM
