HELP! MOUNTs GOT RIPPED OUT
Old May 10, 2007 | 11:59 PM
wha_gwan's Avatar
Default HELP! EnGINE IN A SLANT.MOUNTS RIPPED OFF
Hey..
I have an ek Civic with a gsr..
I thought my tranny was Messed up.. I couldent shift.. then i poped my hood.. I realized my engine was on a BIG slant to the drivers side i checked out the mount.... It wasnt doing anything.. so i took it off...
Turns out the bolts was ripped out of my engine.......I got the pics of the mount.. I circled where it got ripped from....
Could this SLANT Be the reason I cant Put it in gear.....
ANd also.. HOW THE HELL DO I FIX THIS..
thx
Modified by wha_gwan at 1:58 AM 5/11/2007
Old May 11, 2007 | 12:28 AM
chrisw85's Avatar
Yes, the slant could prevent you from putting the car in gear.
If the threads are still in the block, I'd chase them and try reusing that bolt on the mount bracket you have pictured. If the threads in the block are stripped, then more repair will be necessary; helicoil may work.
Old May 11, 2007 | 12:37 AM
wha_gwan's Avatar
Default Re: HELP! MOUNTs GOT RIPPED OUT (wha_gwan)
The bolts are messed UP.. and so is the THREADING on the "virgin"..
(the bolt and the Place it goes in is both messed up..)
what BOLTS are these!>
where can i get them..
advice ?
hints?
Old May 11, 2007 | 01:01 AM
wha_gwan's Avatar
OK..
Here are some pics.. to show u guys WHAT the degree of slant it is....
Could THis EFFECT putting it into gEAR....
AND also..its not starting.(its cranking tho). Could this be the same reason..maybe something got knocked outta place...
Old May 11, 2007 | 01:03 AM
bmoua's Avatar
damn that is bad...i would go to your local junkyard...or look in the classifieds. Finding that mount wont be too hard.
Old May 11, 2007 | 01:05 AM
wha_gwan's Avatar
Default Re: (bmoua)
THe mount is FINE.
as u can see in the picture...
Old May 11, 2007 | 01:36 AM
Team RS2's Avatar
Default Re: (wha_gwan)
sounds like whoever swapped the motor didnt use correct grade bolts, instead of junkyarding used bolts spend the 30 bucks it'll cost at the dealership for some new ones
Old May 11, 2007 | 01:27 PM
wha_gwan's Avatar
would it be possible to rethread the block where it got ripped from without taking out the block?
Old May 11, 2007 | 01:40 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
yeah, you can do it in the car. chances are the threads in the block are wasted, so you will need to heli coil the block. if you have never done this, you will need to take it to a pro, as the heli coil kit/tool isn't cheap, especially for larger sizes that you will need for the mount. good luck.
Old May 11, 2007 | 04:13 PM
wha_gwan's Avatar
HEY GUYS...
a friend of mine works at a machine shop.. He can DO IT!!.. ill take pics of the process.. and some b4 n after on the slant
thax guys
Old May 11, 2007 | 05:01 PM
Xscort's Avatar
the same thing happened to me man...twas a nightmare. i was in the parting lot, and the next thing i knew BAMMMMM, CLUNK!!!! i had a d15b7 in and that same mount, the bolts had stripped out. had to re-tap the whole and add larger diameter bolts. i'm glad the motor didnt break my axle cuz the axle was turning on the motor and my dumb kept tryin to drive the car cuz i thought it was my tranny!! LOL...i'm all good now, good luck!!
Old May 11, 2007 | 05:23 PM
92hatch_cx-t's Avatar
similar thing happened to me once but mine broke my axle and the bolts didnt break like yours....one bolt stripped and the other one broke a piece off the block before it broke....
good luck
Old May 11, 2007 | 05:29 PM
redcoats1976's Avatar
Default Re: (92hatch_cx-t)
ummm...cant you just park on a hill...
Old May 11, 2007 | 05:42 PM
rockenroller6's Avatar
Default Re: (redcoats1976)
Dang looking at those pics makes me want to cry...
Old May 11, 2007 | 07:13 PM
JeffBro's Avatar
Default Re: HELP! EnGINE IN A SLANT.MOUNTS RIPPED OFF (wha_gwan)
I have a different theory about what happened here. Those bolts don't just rip out of that block cause you got sooo much power under the hood. I am willing to bet that someone didnt tighten the bolts all of the way and they sheered off after backing out part way. I have been a mechanic for a a while now and I have see this type of thing happen many times its always because the bolts were loose. Anyhow enough of me being *** hole You might be able to get some fresh bolts from honda, get the ends out, clean out the bolt holes using a thread tap, and reinstall the mount. It might work if there is still enough threads left in there. I would give it a rigorous test drive to make sure its ok.
Modified by JeffBro at 10:05 PM 5/11/2007
fv8s
Apr 29, 2010 12:28 PM
Linked
12
Mar 2, 2010 10:55 AM
tegdude227
May 27, 2009 01:48 PM
gsr336
Oct 18, 2006 05:40 AM
