F-max turbo questions
I noticed that f-max and drag have been kind of duking it out for a while. I was wondering what to big difference is between them. The piping all seems the same, the turbo's are the same, I just don't see what the difference is, reason why I'm asking is because I'm about to buy a turbo kit for my new project, and I was planning on drag, then someone told my that f-max is better. can someone elaborate on this, cause I'm just not getting it. Thanks
as far as I know, Fmax comes with T04B, which is smaller than the drag T04E, it all depends on the car itself..
Fmax comes with MF2 which is their fuel system, 2 Lucan injectors placed before the TB, adding extra fuel, also a boost timig master
Drag comes with FMU, which is a boost dependet fuel pressure riser...
if I were you, get either one, ditch the MF2 or the FMU and get standalone...
but I picked the Drag..so it's the same difference..
fuel managements are different b/w the 2 kits. this is the main difference.
uh oh, i sense an fmu vs. mf2 debate coming on....
edit: i think as with any kit, you can specify turbo sizes
[Modified by vudoo666, 2:28 AM 5/31/2002]
