Do I have everything I need to install this oil pressure gauge?
The guy at O'riellys said this should be all I need. He told me this is a electic oil pressure gauge, but it was my impression any gauge with oil coming into the cabin is mechanical.
If this is in fact all I need, then where do I want to wire this line to? I searched, but theres several different answers. Theres the sensor by the VTEC solonoid, and theres the one below the oil filter, all i need is a little pointing in the right direction
https://honda-tech.com/zerothread?id=1938814
I personally wouldn't run something like that...seems like a mess waiting to happen...
at least get a better hose. that stuff is so brittle, i've seen those things break and shoot oil all in the car.
Guest
Posts: n/a
dude its not worth it. get rid of that ****. my car was loosing oil bc of that **** and almost caused it to lock up. not worth it. stick with the stock oil pressure sender unit.
no, actually, the white piece is the gauge. thats why i thought this was a manual gauge, because theres NO sender unit, just that little brittle white hose.
Okay, this seems seriously hard, all I want to do is measure my damn oil pressure. after taking this back, whats my best option?
From: Where the wild things are in, NY, United States of America
the best thing to do if you do need to run fluids into the cabin is get a gauge head adapter that makes the back of the gauge a -3 or -4 male fitting, then you can use a generic s/s brake line for the connection. a lil more money on top of the gauge, but its about 99% less likely to leak.
standbackimapro
Apr 30, 2006 07:22 PM
W O T
Jan 29, 2005 08:01 PM
