Wheel Stud Replacement
Old May 6, 2007 | 06:31 PM
CodyC142's Avatar
Default Wheel Stud Replacement
I recently noticed a horrible shake in my car, so I get out, look at all the wheels and my front drivers side wheel only had 2 lug nuts on I checked and 2 of the studs had broken right of. Not sure how it happened
Tomorrow Im going over to NAPA to get two more then put them in.
Will I need to pull the whole hub assembly? Or can I slide the studs in from behind without mangeling the threads?
TIA!
Old May 6, 2007 | 06:33 PM
Eran's Avatar
HT White Ops
This took me 5 seconds of searching ....
http://www.50mod.com/fourthgenhatch/wheelstud.html
Old May 6, 2007 | 06:34 PM
turbociviccoupe's Avatar
Default Re: Wheel Stud Replacement (CodyC142)
you will have to pulll the hubs out to put the studs in properly...there is a thread on here on how to do it properly...and also there is another thread to do it with a slide hammer. just search
Old May 6, 2007 | 06:35 PM
eran the ninja just did you a favor
Old May 6, 2007 | 06:37 PM
CodyC142's Avatar
Default Re: (Eran)
Ahh.. On my 93 Si its a little different. Ive heard that the stud actually hits the hub on the other side.
Any other input
Old May 6, 2007 | 06:38 PM
CodyC142's Avatar
Default Re: (CodyC142)
for some reason I cant search on honda-tech. It just wont complete it from my house computer. It just spins and spins and spins and spin.
Old May 6, 2007 | 06:41 PM
t0p_sh0tta's Avatar
^ it's no different.
I was able to bend the dust shield out of the way and get the new stud in place on my 93 EX.
Old May 7, 2007 | 10:07 AM
Budget Racer's Avatar
Default Re: (t0p_sh0tta)
Yes bend the brake shield or like I did snip a lil piece out. If you cant hammer old stud out all the way cut the heads off with a grinder. I still had a tight fit putting new studs in so I used a grinder to make a flat side (Just as much as it takes) which made it possible to clear the blockage. Those Hubs are a pain to remove in my experience (only tried once) so this ghetto method might work for you too.
I have had no problems ever since.
I hate the way Honda makes you take the hub off to change em it's such a Beeoch!!
When all else fails and your broke go Ghetto-tech
Old May 7, 2007 | 11:34 AM
instructor74's Avatar
Default Re: (Budget Racer)
I did all the studs on my 93 Si with out removal of the hub assyit wasn't all that hard but I alos had a hot knife to help get the old studs out.
Old May 7, 2007 | 11:50 AM
Luserkid's Avatar
Default Re: (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">This took me 5 seconds of searching ....
http://www.50mod.com/fourthgenhatch/wheelstud.html</TD></TR></TABLE>
If you do it like this, make sure you weld the stud in the back.
I do all mine like this:
http://www.hondaautomotivepart...INDOW
Old May 7, 2007 | 12:40 PM
apm's Avatar
apm
Default Re: (Luserkid)
when i had my loose front stud i brought it Les Schwab and they took it out for me...I think $15 for it
just bought the replacement stud from honda dealership
Old May 8, 2007 | 12:26 AM
Yup thats how I did it except I barely flatend one side of the stud and it worked great. There was still enough material so that the stud head would stay strong.
Was up Cali
MadVladCivic
Dec 3, 2015 06:50 AM
Midori Green
15
Jan 1, 2008 10:39 PM
drewbie
Welding / Fabrication
Apr 21, 2006 07:28 AM
calvinchang2003
27
Aug 23, 2003 05:09 PM
dynamo
Sep 20, 2002 11:37 AM
