weird whirring / rubbing / humming coming from rear wells on hard turns?
Hmm ive got a weird problem. When i take some turns hard and fast sometimes ill get a strange whirring / rubbing / humming sound from the rear of the car. The sound always comes from the wheel on the same side of the turn, so a hard right will make the back right tire make noise, and a hard left will cause the rear left to make noise.
The right side seems to make the noise more often than the left. I dont think the tires are literally rubbing on anything- they are 13" steelies and are pretty skinny i dont see how they could touch the inside of the fender.. ever. I replaced all the suspension this weekend with kyb agx + ground control coilovers and new LCAs but teh noise is still there...
What could cause the noise? Could it be like a bad rear trailing arm bushing or something? er a worn camber arm in the rear? It doesnt effect driving, its just very annoying and i know its not SUPPOSE to make that noise so id like to remedy it if possible...
any ideas?
any ideas?
How low is your car, and what type of shocks/springs?
It sounds to me like you're dunking your rear suspension, and the tire is rubbing. It sounds like a high-pitched "whhhhhhrrrrrrrrrr"
"dunking rear suspension"? - whats that mean?
car is not low at all, there is about a 1" wheel gap and the coilovers are up as high as they go-
kyb agx and ground control coilovers, stock 13" steelies....
car was making the sound BEFORE and AFTER replacing the oem suspension so i dont think it has to do with ride height...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl »</TD></TR><TR><TD CLASS="quote">how's ur wheel bearings?</TD></TR></TABLE>
Wheel bearings would squeal more than whir, and they'd do it constantly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
Wheel bearings would squeal more than whir, and they'd do it constantly.</TD></TR></TABLE>
in that case i have the same prob as the op, only on one wheel though.
yeah i dont think its the wheel bearings- i had them go on my other car and yeah, they squeal like a bitch, this is more of a hum/whirr sound...
camber in the back is pretty good i think, i mean i didnt have any camber wear issues on the stock suspension and the aftermarket i just put on didnt seem to effect teh camber much cause its not really dumped that low...
Inspected the rear tires for signs of rubbing and they look perfect- even still have the lil rubber hairs on the sidewall from when they were new
i just did a rear disc conversion and one wheel started whirring and making the same symptoms as the op. When I had the drums, my rta bushings were completely ripped, but didn't make any whirring sounds or humming sounds.
govtec
Apr 4, 2005 02:49 AM
OEMedUP
52
Apr 21, 2004 10:41 AM
