help misfiring!!!!!
Old May 5, 2007 | 10:35 AM
iNfAmOuS_E46's Avatar
Default help misfiring!!!!!
VIDEO OF SAID MISFIRING
http://www.youtube.com/watch?v=INOkZIHSa7Q
i have a 99 dx hatch with a stock d16y7 with an ex exh mani an ex intake mani it ran fine for 2 years then it started misifirng but didnt throw any codes then it started running real rich.
i can disconnect injector 4 and the idle stays the same i can disconnect plug wire 4 and nothing changes and it throws p301,p302,p303,p304 and p1300 and p1399 i just installed a new distributor ,wires, cap, rotor,ngk plugs and injectors and still nothing i turn it on and the cel starts blinking like crazy idles like a subby and sounds like a subby when i hit it
Modified by iNfAmOuS_PuTt_pUtT at 8:45 AM 5/17/2007
Old May 5, 2007 | 10:41 AM
Luserkid's Avatar
Default Re: help misfiring!!!!! (iNfAmOuS_PuTt_pUtT)
Im thinking either a grounding issue or a main relay issue. Try both of those.
Old May 5, 2007 | 10:58 AM
ima check the main relay but do you think a bad battery could casue this?
Old May 7, 2007 | 11:26 AM
help
Old May 7, 2007 | 11:40 AM
93egsir's Avatar
so you get misfires on all the cylinders or just #4. I see you get codes for all of them. if its only one cylinder then misfires can be caused by no spark, no fuel, not enough compression. so switch spark plug 4 with 3 and see if the problem stays in cyl 4 or follows the plug. same thing with the inj. perform a compression test.
Old May 8, 2007 | 07:03 AM
i can disconnect wire 4 and nothing changes in the idle same thing if i unplug injector plug 4
Old May 9, 2007 | 07:34 AM
whenever i reset the ecu it idles really low with no cel on for a while
Old May 9, 2007 | 08:51 AM
gotbooost's Avatar
double check the position of the wires on the cap since you just changed that.
Old May 9, 2007 | 08:58 AM
Tomdata's Avatar
Default Re: (gotbooost)
time for a block check to see if your head gasket gave up and a compression/leak down test too. sounds like a mechanical problem to me
Old May 15, 2007 | 08:16 AM
damn idle is so low
Old May 15, 2007 | 08:40 AM
abusedhusband's Avatar
many things it could be. how mechanicaly inclined are you. check valves for cracks, not seating, cracked spark plug, shitty spark plug like autolite plugs i see many people use, rotor, cap, wires, compression,injector, injector pulse. and some other stuff im forgetting.
Old May 15, 2007 | 08:52 AM
Hybrid96EK's Avatar
Default Re: help misfiring!!!!! (abusedhusband)
Check the compression on the #4 cylinder first.....
Old May 17, 2007 | 07:46 AM
BUMPPPPPPPP
Old May 17, 2007 | 07:50 AM
blaster834's Avatar
replace and or switch with another cyl. the spark plug and injector.
if not sounds like a head gasket problem. but do a compression check on all four and if the #4 is low you got a problem
Old May 17, 2007 | 10:26 AM
SOMEONE SELL ME A Z6 HEAD
Old Sep 23, 2009 | 05:19 PM
eguti66's Avatar
did you ever get this problem fixed? i am having the same issue with my 1999 civic ex
Old Sep 23, 2009 | 05:49 PM
h3adw0rkz's Avatar
New User
have you checked the positon of the plugwires as suggested by gotbooost? check it end to end..
have you experimented on advancing/retard the timing before this problem occurred?
what did you do to your car before this happened?
Old Sep 23, 2009 | 08:28 PM
earlylocks's Avatar
problem fixed? or not?
Old Sep 23, 2009 | 08:33 PM
Former User's Avatar
This thread is more than 2 years old.
Mtrester92
Jan 4, 2016 05:31 PM
jibs
Jun 5, 2012 04:44 PM
dsnONE
15
Apr 27, 2012 05:39 PM
h-duced
Jul 16, 2009 02:06 PM
