1998 civic EX no spark
Old Jan 3, 2016 | 09:38 AM
Mtrester92's Avatar
Default 1998 civic EX no spark
Hey everyone, I recently picked up a 1998 civic EX coupe and it has no spark/no start. It cranks fine. I've already put in a new distributor with a coil and all that, new ignition switch, checked the thermostat ground, new plugs and wires and even tried a different ecu. When I turn the key, the CEL comes on for like 2 seconds and I can hear the fuel pump prime and then it goes out. All the spark plugs are wet after cranking. And after cranking for 30 seconds or so, the ecu shows no codes to go off of. I'm pretty much at a loss here and I need help bad. This thing is kicking my a**
Old Jan 4, 2016 | 07:06 AM
Mtrester92's Avatar
Default Re: 1998 civic EX no spark
Bump. I really need some help
Old Jan 4, 2016 | 05:31 PM
nub's Avatar
nub
With the key in the run position, at the distributors electrical connector, with a volt meter check the blk/yel wire. There should be battery voltage, if not check the under dash #9, 15A fuse.
wascly
Sep 21, 2010 08:36 PM
garrettrauch
Aug 31, 2010 09:44 AM
Noo_Ish_mee
11
Jul 13, 2009 09:47 AM
desiromeo812
Dec 18, 2008 05:35 PM
p.c.p
Oct 6, 2006 07:10 PM
