Diagnosis of Plug and suggestions.
I have a JDM b18c type r swap in my da and i went to do a routine tune up... oil change, trans fluid, plugs, fuel filter, etc etc. and when i pulled the plugs i noticed they looked like this.
The tips are not white but they are a sort of deep grey. I noticed that they were bkr6e's and not bkr7e's .... my question is are they a little lean or do they look fine. I've put bkr7e's in the car and just wondering if that is a little lean will putting the colder plugs in help eliviate that problem.
pretty sure stock heat range is 6. but you can use 7 no problem. those pics are hard to tell how good/bad they are. and really the only true way to check a plug is to do a WOT pull and kill the engine as soon as you let off the gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">pretty sure stock heat range is 6. but you can use 7 no problem. those pics are hard to tell how good/bad they are. and really the only true way to check a plug is to do a WOT pull and kill the engine as soon as you let off the gas.</TD></TR></TABLE>
And then look or listen for what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6-DC2 »</TD></TR><TR><TD CLASS="quote">
And then look or listen for what?</TD></TR></TABLE>
no then you pull over and pull the plugs. or if on a dyno, same things just kill the engine and pull the plugs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d3viant »</TD></TR><TR><TD CLASS="quote">you sure stock heat range is 6... its all over honda tech that JDM itr heat range is 7</TD></TR></TABLE>
All I know is USDM is 6, and Im using a 7. :shrugs:
USDM ITR plugs (the ones you go and buy from Acura) are a heat range 6, Everywhere else in the world, ITR's use a heat range 7 and thats what outside US honda sells for them. I believe it has to do with the difference in the compression ratio. The US is 10.6 to 1, while the rest of the world is an 11 to 1 (except for 96-97's)
milkwasabadidea
11
Aug 29, 2011 08:08 PM
