Quick Question Please Read.
Old May 3, 2007 | 10:56 AM
DenzComp's Avatar
Default Quick Question Please Read.
Hey-
I've been having a problem with my hatch. It's a standard. Whenever I let off the gas too quickly, it jerks the entire car. If I'm going down the highway and let off the gas I can see the shift stick move forward.
Could the problem be that I need to replace my shift stabilizer bushings? I don't think it's the motor mounts, could be though.
Thanks in advance,
-Dennis
Old May 3, 2007 | 11:07 AM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: Quick Question Please Read. (DenzComp)
Check your motor mounts.
Old May 3, 2007 | 11:14 AM
89s1's Avatar
Default Re: Quick Question Please Read. (ILcrxsi1)
bad motor mounts will usually make a bit of a "clunk" sound when the load on the engine is either abruptly applied or removed, depending on which mount(s) are toast. but i will also say that in the 100's of 5 speed cars i have driven, you'll always get feedback from the engine through the gearshift when there is a physical connection.
have you been under the car to actually look at anything yet? that would probably answer your question rather easily, as a bad rubber mount or bushing will be hard, and full of cracks.
hope this helps, but seriously, go jack up your car.
Old May 3, 2007 | 11:45 AM
DenzComp's Avatar
I will.
I just wanted to know if these bushing could cause that problem. Figured I'd start with the cheaper of the options first.
Old May 3, 2007 | 01:50 PM
DenzComp's Avatar
Anyone else have any input?
Old May 3, 2007 | 01:57 PM
jdmd15bciviconrice's Avatar
Default Re: (DenzComp)
Check the front and rear mounts thats why my stick did that 2 years ago and I replaced the shift linkage bushings as well so check those too.
attica
13
Feb 17, 2010 08:23 PM
TheBigSkeeza
13
Jun 14, 2009 12:00 PM
spencedogg
Nov 2, 2003 09:06 AM
Briman2021
Jan 31, 2003 09:49 PM
