D16a turbo
Old May 2, 2007 | 08:21 PM
97civicdxt's Avatar
Default D16a turbo
Alright, i recently pieced together my turbokit, i started with a d16a motor which i got off rising sun motors. It is equivalent to the d16y7 which i swapped out of my 97 civic dx coupe, I got the conversion harness for obd2a to obd1. I installed the turbo kit and kept the obd2 and tried using an fmu/missinglink but it burnt richer then bill gates and then bogged out past 10% throttle and died. So i then converted it to obd1 witht he conversion harness, a po6 ecu and the 2 wire iacv manny off a 94dx coupe. Still i got the same problem, burns really rich and apst 10% it dies. Also pre turbo my car had a vacuum of -20 at idle pro turbo im at -10 vacuum at idle and cant seem to find any leaks. So just to sweetin the deal everyone told me from turbod16 and homemadeturbo to buy the tuner package#1 from xenocron, so i did i socketed it and installed everything and when talking to a person from xenocron.com when i called theys aid they havea basic basemap already on the chipt hat would run my car, which it did but my car runs the exact same. So anyone have any idea what could be messing with my vacuum besides a leak, because i cant seem to find a leak anywhere. Also the fuel? And also i took my stock y7 TB which originally on the goofy y7 IM was at a vertical angle and converted the throttle pulley off the 94 dx TB so i could use my stock TB on the 94 IM, worked jsut fine but justed wanted to make sure i through that out there incase its the TPS messing with my vacuum and richness in some wierd ways, Any help is much appreciated and the faster i get it runnin the faster we get some more vides of d16ings pwning 5.slows I will list my specs
D16a stock internals
D15 intake manny from 94 dx coupe
.57 trim turbo
precision 310cc injectors
tsudo exhaust
38mm wastegate
rs bov
giant FMIC
Old May 2, 2007 | 09:09 PM
97civicdxt's Avatar
Default Re: D16a turbo (97civicdxt)
I know someone out there has had to turbode a ek d16y7 and converted to obd1 using crome.
Old May 2, 2007 | 09:13 PM
minime-civic's Avatar
* B A N N E D *
you type that like your reading it out of a book HT noob!
Old May 2, 2007 | 09:15 PM
* B A N N E D *
Default Re: D16a turbo (minime-civic)
haha my pic is in front of your house lol
Old May 2, 2007 | 09:29 PM
97civicdxt's Avatar
lol u bastard, I NEED MY BOOST FIXED, this guy will vouche for the gayness of my car, it refuses to boost, c-diz and his honda-techn
rick_rabies
Jun 16, 2010 06:25 AM
vtec-adykt
Apr 14, 2007 10:42 PM
mkinpwrat12g's
Sep 8, 2005 08:04 PM
B18 CYA
Jun 1, 2004 11:22 AM
