turbo help
Old May 2, 2007 | 07:53 PM
vtec99ej's Avatar
Default turbo help
found a full turbo kit off of greddy for my 99 civic...and im not exactly what of what all im gonna have to do to run about 16lbs of boost...ive been told thats the most you can run if you build it...but im not exactly sure what im needing in order to build the motor to hold it..ive heard the d16y8 can hold 250 hp max...just needing help guys...thanks.
Old May 2, 2007 | 08:39 PM
deadline's Avatar
250hp on stock internals...thats what u probably heard...
Old May 3, 2007 | 05:24 AM
MJ0LNIR's Avatar
Default Re: turbo help (vtec99ej)
There's lot of debate over what you can run on stock internals, but all of it seems to be "enough to make your car fun, not enough to make it a beast" from what I've read.
Search around in the FI forum, they'll be glad to help. TurboD16.com and Homemadeturbo.com are your friends too.
Old May 3, 2007 | 08:28 AM
97Ej6mike's Avatar
The stock recomneded boost is about 6-8lbs, but i know ppl who have run 10-12 psi without a problem. 16 seems a bit high for a singlecam, you might want to do some research into that some more before you end up blowing your motor.
Old May 3, 2007 | 08:36 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">The stock recomneded boost is about 6-8lbs, but i know ppl who have run 10-12 psi without a problem. 16 seems a bit high for a singlecam, you might want to do some research into that some more before you end up blowing your motor.</TD></TR></TABLE>
All depends on the turbo, 8lbs is two totally differen't things on differen't trimmed turbos.
Old May 3, 2007 | 10:17 AM
doood's Avatar
been there done that
is that turbo even going to be efficient with that much boost?
Old May 3, 2007 | 10:29 AM
Ek Forever y0!
Default Re: turbo help (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">is that turbo even going to be efficient with that much boost?</TD></TR></TABLE>
Stock greddy kits in any turbo trim are usually designed for lower boost
I.E. 6-10 lbs.
Old May 3, 2007 | 10:42 AM
lsturboswap's Avatar
probaly wants to run arounf 7-9 pounds to be safe
94Eg_SnatchBack
Oct 25, 2011 12:41 PM
aznology
Jan 1, 2010 06:31 PM
dannyb2134
57
May 27, 2009 05:54 PM
bigandy90
Feb 14, 2008 01:57 AM
eghatch16
Nov 2, 2006 04:55 AM
