Need front brakes!!!
ok i havent found my answers yet but have an Si with b16 stock brakes, i talk to someone today who had someone put front 95 gsr brakes knuckles and everything but, people i ask say it wont work. im not good in this brake swap thing. so any positive info. would be awesome..
found this in the FAQ it might help. https://honda-tech.com/zero...age=1
http://www.ef-honda.com/ben/EFhybridsus.php
like he said ^^^^^^^^^^ u can use the rotors and calipers off the ex too,there the same size. i would recomend the master cylinder aswell. some brembo blanks and good pads with braided brake lines and ur set. good luck,its not hard at all. u can use the automotive manual to guide u along.
IIRC, you can use the 90-93 Integra front knuckles as well. The 90-91 EX ones weigh less though
Also, I believe there was a guy that did do a ITR knuckle swap and had to slam it to get the camber near zero.
just a warning if you use any of the 90-93 integra knuckles front or rear it will push the wheels out a few mm. one of my cars has integra knuckles front and rear with pretty flush wheels, when i switched them out the tires started rubbing so i had to roll the fenders a bit.
i recomend using all 88-91 ex parts.
