flywheel wobbles
Old May 2, 2007 | 01:27 PM
Eibach95Civic's Avatar
Community Builder
Default flywheel wobbles
my flywheel is wobbling on my engine. What could this be caused from and is it ok to drive on for awhile?....it's not a bad wobble but you can notice it
Old May 2, 2007 | 01:33 PM
994door's Avatar
Default Re: flywheel wobbles (Eibach95Civic)
is it oem, or aftermarket?
Old May 2, 2007 | 01:34 PM
Archidictus's Avatar
Unceasing Measure
How do you know your flywheel is wobbling? If it's so out of balance that it's wobbling, it's going to damage the bearings and/or the crankshaft. You need to get it fixed immediately.
Community Builder
Default Re: flywheel wobbles (994door)
oem
Old May 2, 2007 | 01:36 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eibach95Civic &raquo;</TD></TR><TR><TD CLASS="quote">it's not a bad wobble but you can notice it</TD></TR></TABLE>
my engine sat for 3 years before i put it in my car. Could it be warped?
Hybrid-Fusion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eibach95Civic &raquo;</TD></TR><TR><TD CLASS="quote">my flywheel is wobbling on my engine. What could this be caused from and is it ok to drive on for awhile?....it's not a bad wobble but you can notice it</TD></TR></TABLE>
Flywheel or main pulley? How did you notice it wobbling? If my flywheel was wobbling I probably wouldn't drive it. That means: 1) Your flywheel is bent. 2) The bolts are coming loose from the crankshaft. 3) Your crank is bent. Like I said, I wouldn't drive it.
Old May 2, 2007 | 01:37 PM
Community Builder
Default Re: flywheel wobbles (Hybrid-Fusion)
flywheel
i can see it rock a little bit
Old May 2, 2007 | 03:13 PM
doood's Avatar
been there done that
is the engine in the car? how can you see it wobbling?
Old May 2, 2007 | 04:51 PM
Community Builder
Default Re: flywheel wobbles (doood)
engine is in car.
I start car. open hood. i have no flywheel cover, therefore i can see it wobble a little bit
Old May 2, 2007 | 05:04 PM
doood's Avatar
i would definitely replace it then. it can lead to bigger problems if you continue to drive with it.
Boostage
Jul 5, 2007 03:01 PM
mattdenali
Sep 13, 2005 04:19 PM
mrx
Oct 1, 2004 11:17 AM
Anthonyl469
26
Jul 22, 2004 10:29 AM
yellowbuffalo
Jun 20, 2003 04:45 PM
