what do i need for a type-r master cylinder swap?
https://honda-tech.com/zerothread?id=818263
save yourself the headache and get a matching mc/bb set
however, as long as the flanges match, you should be fine
didnt you ask this before?
i know i need a non-ABS master cylinder and booster, and i was planing on buying a new master cylinder for a type-r at honda or autozone since the one in my project car (13/16"s non abs) is bad and leaky. and someone near me is parting out an RS integra (15/16" bore) just want to know if i can use that booster and a new itr master?
If this is for a 92-95 non abs just use the 15/16" 91 civic ex sedan master cylinder. It will match up with your brake booster and existing lines. 1/16" under a full inch and 1/8" more than what you have already with or without a 40/40 prop valve will give you a better pedal feel and bolt right up.
This is just my suggestion otherwise good luck.
eskerley
Jan 23, 2008 03:24 PM
adrian1281
Aug 23, 2003 09:43 PM
