Secondar or Primary o2 sensor???
Old May 1, 2007 | 06:00 AM
chue_li's Avatar
Default Secondar or Primary o2 sensor???
i have a ek hatch and as you know, both sensors are close by each other. is there a way you can tell which plug (on engine harness) is the one for primary or secondary. thanks
Old May 1, 2007 | 07:43 AM
Mr.EM1_EK's Avatar
Default Re: Secondar or Primary o2 sensor??? (chue_li)
trace the wire back from the sensor
Old May 1, 2007 | 07:45 AM
97Ej6mike's Avatar
Primary is the top one before the cat, and secondary is under the cat, which is mainly for emmisions testing reasons. The primary one helps aid the motor in correcting its air\fuel ratio by measuring the burn in the exhaust.
Since you have the Y7 motor, the CAT is on the header itself, just behind the radiator, so they arent too hard to reach.
Old May 1, 2007 | 07:50 AM
Purification's Avatar
YUp, Primary is the top one.
Old May 1, 2007 | 07:54 AM
h2392si's Avatar
Default Re: Secondar or Primary o2 sensor??? (Purification)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Purification &raquo;</TD></TR><TR><TD CLASS="quote">YUp, Primary is the top one.</TD></TR></TABLE>
X2
Old May 3, 2007 | 06:19 AM
chue_li's Avatar
Default Re: Secondar or Primary o2 sensor??? (h2392si)
i know that the top o2 sensor is the primary....but the problem is which plug on ENGINE HARNESS is for which o2 sensor??
Old May 3, 2007 | 10:53 AM
chue_li's Avatar
Old May 13, 2007 | 11:15 PM
Bruce Lee's Avatar
Can someone post a pic of the o2 sensor 1 in bank 1, which says input voltage too low.
This is a civic LX, it has 2 o2's. 4 wires each.
Got a code P0131. Input voltage from o2 sensor 1 in bank 1 is too low for current conditions. Retards cant put in in plain terms haha, anwyay....It says closest to the cylinder head b4 the cat converter. Not sure which of the 2 is this loc talking bout.
Old May 13, 2007 | 11:19 PM
gezzuzz's Avatar
Default Re: Secondar or Primary o2 sensor??? (Bruce Lee)
the 2nd o2 has a red/yellow wire
Old May 14, 2007 | 05:29 AM
Bruce Lee's Avatar
Default Re: Secondar or Primary o2 sensor??? (gezzuzz)
Actually I checked both, they are within reach, each one had 4 wires. My old civic only has one wire.
Old May 14, 2007 | 06:40 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">the 2nd o2 has a red/yellow wire</TD></TR></TABLE>
And a Wht/Red wire too.
BOTH of them have a Blk/Yel and Blk/Wht though.
Old May 14, 2007 | 07:07 AM
Bruce Lee's Avatar
Default Re: Secondar or Primary o2 sensor??? (EE_Chris)
i gotta go get a socdket to get this thing off, seems all rusted, any advice on removing it?
Bruce Lee's Avatar
Hehe way too tight......
zerodohc
Jan 10, 2013 12:41 PM
Coltmorris
Oct 27, 2006 01:29 PM
EJAYATE
Jun 1, 2005 03:51 PM
silentblackhat
Feb 15, 2005 10:33 AM
JoshRambo
May 15, 2003 07:16 PM
