Secondar or Primary o2 sensor???
i have a ek hatch and as you know, both sensors are close by each other. is there a way you can tell which plug (on engine harness) is the one for primary or secondary. thanks
Primary is the top one before the cat, and secondary is under the cat, which is mainly for emmisions testing reasons. The primary one helps aid the motor in correcting its air\fuel ratio by measuring the burn in the exhaust.
Since you have the Y7 motor, the CAT is on the header itself, just behind the radiator, so they arent too hard to reach.
Re: Secondar or Primary o2 sensor??? (Purification)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Purification »</TD></TR><TR><TD CLASS="quote">YUp, Primary is the top one.</TD></TR></TABLE>
X2
X2
Re: Secondar or Primary o2 sensor??? (h2392si)
i know that the top o2 sensor is the primary....but the problem is which plug on ENGINE HARNESS is for which o2 sensor??
Re: Secondar or Primary o2 sensor??? (chue_li)
Can someone post a pic of the o2 sensor 1 in bank 1, which says input voltage too low.
This is a civic LX, it has 2 o2's. 4 wires each.
Got a code P0131. Input voltage from o2 sensor 1 in bank 1 is too low for current conditions. Retards cant put in in plain terms haha, anwyay....It says closest to the cylinder head b4 the cat converter. Not sure which of the 2 is this loc talking bout.
Re: Secondar or Primary o2 sensor??? (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">the 2nd o2 has a red/yellow wire</TD></TR></TABLE>
And a Wht/Red wire too.
BOTH of them have a Blk/Yel and Blk/Wht though.
Coltmorris
10-27-2006 01:29 PM
silentblackhat
02-15-2005 10:33 AM
