Increase wheel offset
Old Apr 30, 2007 | 05:22 PM
islander76's Avatar
Default Increase wheel offset
Hey everyone! I currently bought 18 x7.5, +42mm, 4 x114.3 wheels. My problem is, now the wheels are sticking out past the fender a tad bit. Is there a way to increse the offset of the wheel by having it shaved down to a +48 offset or way to decrease the thickness of the hub on my rotors? I own a 2000 Honda Accord Ex/2dr. I would like the wheels to be slightly sunken in the fender well or at least flush with it. Any info would be greatly appreciated. Also, if anyone knows of any shop in the San Diego or Los Angeles area that could help me out please let me know. Thanks
Old Apr 30, 2007 | 08:12 PM
toyomatt84's Avatar
Sanji
You could roll/pull the fenders, run a little bit negative camber, or run a narrower tire setup to make them fit better.
Old Apr 30, 2007 | 10:29 PM
r.wright's Avatar
Default Re: (toyomatt84)
is the car lowered cuz that offset sounds very modest to me. what size tires are you running?
Old Apr 30, 2007 | 11:07 PM
islander76's Avatar
Default Re: (mr. R*L*X)
My car isnt't lowered yet because I believe my wheels may rub up against the fender. Im using 225/40 -18 tires. And i'm planning on purchasing some Tein Type Basic coilovers. Btw, when looking at my car from the front my wheels stick out about 1/4". Appreciate the help guys...keep em coming. thanks.
Old Apr 30, 2007 | 11:10 PM
r.wright's Avatar
Default Re: (islander76)
my car looked the same way. i had 18x7.5 +38 OFFSET with 225/40 also
but when i lowered it it looked just fine and did not rub up front.
Old May 1, 2007 | 06:18 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Increase wheel offset (islander76)
You're better off with 215/45-18.
Old May 1, 2007 | 09:41 AM
r.wright's Avatar
Default Re: Increase wheel offset (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You're better off with 215/45-18.
</TD></TR></TABLE> he is right
only reason i used those tires is because they came on the rims when i bought new from the showroom.
Valenciabrihh
Feb 4, 2015 03:06 PM
meric0786
Jul 10, 2011 11:16 AM
2000HondaEm1
Sep 14, 2009 09:10 PM
pcteck
Jun 16, 2009 09:46 PM
silverSOHC
Jan 3, 2007 12:00 AM
