help w/ wheel sizing
Old Dec 30, 2006 | 10:30 AM
silverSOHC's Avatar
Default help w/ wheel sizing
will 17x8 4x100 wheels w/ an offset of 32mm or 48mm fit on my 99 ex coupe?.... if so what size tire should i go with?
Old Dec 30, 2006 | 12:41 PM
silverSOHC's Avatar
Default Re: help w/ wheel sizing (silverSOHC)
bump
Old Dec 30, 2006 | 01:38 PM
nsxtasy's Avatar
H-T Order of Merit
Get the proper size tires for the CAR, not for the WHEEL. Then make sure the wheel width is okay.
205/40-17 is the proper size for 17" wheels on a '99 Civic.
Most 205/40-17 tires are approved for wheels 7.0-8.0 inches wide, so you can use them on 17x8 wheels.
What's the offset and wheel width for the stock wheels on your car? You can use that to figure out what offset for 8-inch-wide wheels will position the tires the same as your stockers. As long as you do that, they should fit fine.
Old Jan 3, 2007 | 12:00 AM
vtecsi00's Avatar
stock backspacing is 5.27.......32mm backside is 5.76....48 backside is 6.39......
all you have to do is measure the rest of the wheel from the hub out towards the fender to see how much clearance you have now.....3.24 from the hub towards the fender on the 32mm and 2.61 towards the fender on the 48mm
Samuels
Honda CR-V & Element
Feb 17, 2013 03:30 AM
darkwater_ghost
Jul 17, 2009 09:33 AM
400whp
May 27, 2009 03:13 PM
Sean @ ESG
Nov 26, 2008 07:32 PM
TypeR 01 886
Oct 23, 2003 06:32 PM
