ECU compatability Auto/Manuel Trans.
Old Apr 30, 2007 | 10:58 AM
Budget Racer's Avatar
Default ECU compatability Auto/Manuel Trans.
Hello,
I did a lil search and rendered no answers so here it go Honda heads.
I am getting a D16y8 sohc vtec motor and was wondering if I change the Auto Trans to a Manuel Trans will the same ECU work for either?
Thanx, Budget Racer
Old Apr 30, 2007 | 10:59 AM
sicones's Avatar
Default Re: ECU compatability Auto/Manuel Trans. (Budget Racer)
you need a manual ECU
Old Apr 30, 2007 | 11:03 AM
Thanx 4 fast reply.
A friend told me different but I thought he might be wrong. That sux cause the ECU is chipped too but I dont want no wussy Auto Trans.
Thanx, Budget Racer
Old Apr 30, 2007 | 11:06 AM
bellsdelsol's Avatar
Actually I believe you can modify the an auto ECU to use it on a manual. I would check the Marketplace and talk to one of the companies that does ECU modifications as I am sure one of them would be able to help you out. From what I heard its a minor change and anyone that knows how to chip should know how to make the change.
Old Apr 30, 2007 | 11:07 AM
Relic1's Avatar
OBD1 - auto-->manual swap is really easy.
OBD2 - auto-->manual swap is not easy.
Old Apr 30, 2007 | 11:16 AM
THC07's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 - auto--&gt;manual swap is really easy.
OBD2 - auto--&gt;manual swap is not easy.</TD></TR></TABLE>
is it obd1 or 2
Old Apr 30, 2007 | 11:19 AM
Rainy City's Avatar
Default Re: (THC07)
I believe d16y8's came in 96+ civic ex's. And everyone knows ob2 starts at 96.
Old Apr 30, 2007 | 11:20 AM
JDM_SOHC's Avatar
Default Re: ECU compatability Auto/Manuel Trans. (bellsdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bellsdelsol &raquo;</TD></TR><TR><TD CLASS="quote">Actually I believe you can modify the an auto ECU to use it on a manual. I would check the Marketplace and talk to one of the companies that does ECU modifications as I am sure one of them would be able to help you out. From what I heard its a minor change and anyone that knows how to chip should know how to make the change.</TD></TR></TABLE>
you just have to resolder twice... RP17 and RP18 on the ecu, i did it to my p28 when i first got it.. there was a writeup but i have no ECU knowledge and i did it fine with no problems, u just have to have a steady hand and partial brain waves and ull be ok haha.. you do however need a little peice of solder though cuz u have to jump the RP18 resistor... GL man...
edit: i found this pic that should be all you need if ur OBD1 anyways.. from the way it sounds OBD2 may be different but check it out... Where RP17 is you have to desolder that resistor and leave nothing there, than RP18 is for auto to so you desolder RP18 an just use a peice of jumper wire to solder back in place of the resistor on RP18 and then your set... By using the jumper wire it resets the values of RP18 and basically just bypasses it...
Old Apr 30, 2007 | 12:01 PM
Ya yall its the dreaded OBD II
So I guess im screwed. Off hand any 1 know what ECU to look 4?
Its a 99 D16y8 sohc vtec
Old Apr 30, 2007 | 12:02 PM
Default Re: (Rainy City)
OBD II
Old Apr 30, 2007 | 12:11 PM
JDM_SOHC's Avatar
Default Re: (Budget Racer)
yeah bro if ur all OEM than u should have an OBD2 P2P ecu in ur ride.... Probably easier/cheaper to just get a manual version "about 50 bucks is what it prolly will be around"..
Old Apr 30, 2007 | 12:20 PM
THC07's Avatar
Default Re: ECU compatability Auto/Manuel Trans. (JDM_SOHC)
FYI, all you have to do to OBD1 is cut rp17, IC16,IC15. no need to use soldering iron or anything, no need to put a jumper on rp18 either. you can use finger nail clipers to convert a auto to manual. nail clipers ftw
Old Apr 30, 2007 | 12:23 PM
JDM_SOHC's Avatar
Default Re: ECU compatability Auto/Manuel Trans. (THC07)
lol where were u at about 3 years ago when i first was beating my head on the wall wondering this haha... pgmfi.org's writeup says the whole RP17 RP18 thing thats why i did it that way, but glad to see theres an easier way....
Old Apr 30, 2007 | 01:20 PM
Relic1's Avatar
P2P-A12 - 99-00 EX sedan/coupe manual
P2P-A92 - 99-00 EX sedan/coupe auto
BTW, leaving RP18 unjumpered can cause CEL19 in some ECUs. I've seen it twice now. But I've also seen 25+ converted without the jumper with no problems...
Old Apr 30, 2007 | 02:55 PM
Thanx relic 1 short sweet simple answer I was looking for.
jack sparrow
Aug 28, 2009 08:24 PM
akouznet
May 24, 2009 06:50 PM
scuzz
Sep 24, 2008 02:45 PM
I got a honda
Sep 20, 2006 07:51 PM
TEG777
Jun 2, 2005 07:02 PM
