HELP: vtec keeps turning off
hi guys, i have this problem with my 1st gen b16...whenever i go about 85 mph for an extended period of time (10 seconds or so), or whenever i'm racing to redline, my vtec just turns off...what's wrong? well, all i know is that my check engine light comes on after vtec engagement (about 5000 rpm), and i've checked the code, it has to do with the vtec (forgot what my friend said it was but it had to deal with vtec)...pls help, my b16 is just a zc now....
make sure you have enuff oil in it vtec works off of oil pressure also , make sure the connection is good on the solenoid . if you take the solenoid off there is a screen on it make sure it isn`t cloggedup .
yea so anyways, i'm still having this problem, i checked my oil and its about 75% to where the top hole is on the dipstick...the connections seem fine as well...anything else that could be an easy check/fix?
Did you add VTEC fluid? that always helps. =x....or maybe you should add the clapper like i did, when i want VTEC to turn on i clap on, clap off.
dang, i hate to post twice but i was thinkin to slow. instead of jumpin the vtec wire to 5v just stick a voltmeter on there and see what it says when you engage into vtec, again have a friend sit shotgun to read the meter so you dont drive off the road.
oh yea...one more problem...when my vtec is working, my fuel will cut out on me around 7500 rpm's...i dunno anymore
yeap, that's me...thanks...its got a lot of paint chips now though...and i don't have any good looking rims on coz i have no tires left on them...
yeah sounds like you do have a automatic ECU. I have one on my B16A too it sucks. And the fuel cut off is at 7400. Sometimes my vtec doesn't work either very strange, still trying to figure it out also
