rod knock??? searched
Old Apr 30, 2007 | 12:27 AM
92b16si's Avatar
Default rod knock??? searched
I just bought this car. I dont know if its a rod know or just need a really bad valve adjustment. It is really loud when you turn it on. when I drove it . it ran fine was doing 65 like nothing. It wasn't making a noise at this speed. But at a stop it will dye out. will be doing a compression test tomorrow.
Old Apr 30, 2007 | 05:58 AM
Crispy's Avatar
Default Re: rod knock??? searched (92b16si)
rod knock would sound like a hammering noise comming from the bottom of your engine
Old Apr 30, 2007 | 09:29 AM
pdiggitydogg's Avatar
rod knock is also not continuous - it tends to happen under acceleration or load
valve chatter is all the time
Old Apr 30, 2007 | 09:39 AM
Rainy City's Avatar
Default Re: (pdiggitydogg)
Take a hammer and hit your block with it. Thats what it sounds like.
Old Apr 30, 2007 | 09:47 AM
smart...
thats not really a very good explanation though, because piston slap will sound the same as that too
Old Apr 30, 2007 | 11:10 AM
92b16si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">rod knock is also not continuous - it tends to happen under acceleration or load
valve chatter is all the time</TD></TR></TABLE>
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rainy City &raquo;</TD></TR><TR><TD CLASS="quote">Take a hammer and hit your block with it. Thats what it sounds like.</TD></TR></TABLE> thanks will try that if its pston splap or rock knock it doesnt matter I just want to know if i should buy a new motor or fix the valve chatter
Old Apr 30, 2007 | 11:12 AM
Rainy City's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">smart...
thats not really a very good explanation though, because piston slap will sound the same as that too</TD></TR></TABLE>
Well he shouldn't be getting piston slap when he's at operating temp unless his motor is on its way out.
Old Apr 30, 2007 | 12:13 PM
or perhaps aftermarket pistons that he didnt mention
Old Apr 30, 2007 | 03:24 PM
92b16si's Avatar
stock motor it sounds nothing like when I hit it with a hammer. can I tell if I take off the head??
Old Apr 30, 2007 | 03:41 PM
eg6civic1538's Avatar
my waterpump on my Ls sounded just like that, take a flat head screwdriver and put it to where you think the knock is, and listen to through the handle...
Old Apr 30, 2007 | 05:24 PM
iceman7329's Avatar
Default Re: rod knock??? searched (eg6civic1538)
Sounds like the valves, mine was doing the same thing and dying down when you stop.
Old Apr 30, 2007 | 08:54 PM
92b16si's Avatar
Default Re: rod knock??? searched (iceman7329)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iceman7329 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the valves, mine was doing the same thing and dying down when you stop.</TD></TR></TABLE> thats excatly what it does. how can you tell do I pull the head??? or what???
Old Apr 30, 2007 | 08:56 PM
iceman7329's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16si &raquo;</TD></TR><TR><TD CLASS="quote"> thats excatly what it does. how can you tell do I pull the head??? or what???</TD></TR></TABLE>
Pull the valve cover off and bring the #1 piston to TDC and check the clearance on the rockers.
Old Apr 30, 2007 | 09:17 PM
92b16si's Avatar
Pull the valve cover off and bring the #1 piston to TDC and check the clearance on the rockers.</TD></TR></TABLE>
thanks will do this tomorrow
Modified by 92b16si at 10:38 PM 4/30/2007
Old May 1, 2007 | 06:34 AM
Crispy's Avatar
is the noise comming from the top or the bottom? I'd check that first
Old May 1, 2007 | 07:08 AM
92b16si's Avatar
Default Re: rod knock??? searched (Crispy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crispy &raquo;</TD></TR><TR><TD CLASS="quote">is the noise comming from the top or the bottom? I'd check that first</TD></TR></TABLE>
I cant tell
RevrsOne
Other Make Vehicles
Aug 21, 2012 06:50 PM
preludeboybmw
Sep 29, 2010 04:21 PM
jdmboy96
18
Apr 25, 2009 11:16 AM
hatchback_al
13
Apr 25, 2004 09:29 PM
