How can you tell how old your engine is?
Old Apr 29, 2007 | 11:06 AM
randommiker's Avatar
Default How can you tell how old your engine is?
I have a JDM d15b and was wondering the year of the motor and how old it is.
Determining on a engine swap or just pepping my motor. Getting kinda iffy on what to to.
Old Apr 29, 2007 | 11:08 AM
harmonator84's Avatar
Default Re: How can you tell how old your engine is? (randommiker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randommiker &raquo;</TD></TR><TR><TD CLASS="quote">I have a JDM d15b and was wondering the year of the motor and how old it is.
Determining on a engine swap or just pepping my motor. Getting kinda iffy on what to to. </TD></TR></TABLE>
Really you just look at the engine code on the block. There is no way to tell the EXACT year the motor was made. You can just tell what year range its from... Example=88-91, or 90-93
Old Apr 29, 2007 | 11:11 AM
what does the engine code consist of. All i know is.. its says D15B thats it. Where is the engine code located
Old Apr 29, 2007 | 11:20 AM
Looking at the engine codes. It says my engine was from a 91-99 Civic VTI VTEC. Ok.. but my engine is not a VTEC and its DPFI. iM WAY CONFUSED
Old Apr 29, 2007 | 11:31 AM
Crx Jimmy's Avatar
Default Re: (randommiker)
you can tell the year it was made or at lest the head, if the exhaust heat shield is off look above the manifold on the side the dizzy is on. there should be a bunch of # that look like this (9/2) the first set of numbers is the year. a 9/2 means 1992.
Old Apr 29, 2007 | 11:41 AM
Ok i looked it has from the the left starting form the distributor a boxed in pm3-13, beside that 9/5 then on down to the right it says 2/2
Old Apr 29, 2007 | 12:33 PM
lsvtec_cp's Avatar
New User
It's a 95 bud. Plus the year don't matter, it's what you got. D15B gives it away right then and there how powerful your motor is, if it's stock that is. If you're worried about the year of your car you shouldn't be mobbin a honda.
Old Apr 29, 2007 | 12:47 PM
Default Re: (lsvtec_cp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec_cp &raquo;</TD></TR><TR><TD CLASS="quote">It's a 95 bud. Plus the year don't matter, it's what you got. D15B gives it away right then and there how powerful your motor is, if it's stock that is. If you're worried about the year of your car you shouldn't be mobbin a honda.</TD></TR></TABLE>
Good first post
Old Apr 29, 2007 | 01:13 PM
Default Re: (harmonator)
yeah i understand its a 95 but i just bought this car. The 95 only tells me the year of the head. The guy i bought it from tells me replaced the old engine in it cause it blew. Im just trying to see if he just swapped heads and thats it.. cause it does still have the DPFI. If the dude swapped heads then the 95 mpfi sould be on it.. well at least thats what the engine codes refer to on the 92-95 engines. Soory bro im new to this import tuning world.. ya gotta start somewhere lol. Im use to tunning americian cars. So.. far im iffy about this engine. If i swap i may need some links and help if ya can. Not worried about money. I also see the B16 is nice but to much of a hassle to swap.
Old Apr 29, 2007 | 01:37 PM
91ED7Si's Avatar
im curious about mine now ima go take my heatshield off and see i think its a 97 i was told
D16a vtec from jdm integra thats all i know except it says a/t on the valve cover so i assume it was an auto.
so atleast it wasnt over revved or banged off the rev limiter a bunch.
Un Spun
Jan 23, 2015 06:16 AM
Lil SyKe
Jul 17, 2010 03:25 PM
randommiker
Apr 27, 2007 07:55 PM
Socratez
Oct 1, 2006 09:12 PM
wadafa
Mar 22, 2003 07:10 PM
