Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
need help on 06 civic intake install ??? but there is a problem...
Old Apr 28, 2007 | 09:32 AM
jnuanz382's Avatar
Default need help on 06 civic intake install ??? but there is a problem...
i install aem cold air intake now the car will not start.. the stater is cranking but the car will not fully start..it just die .....
Old Apr 28, 2007 | 09:44 AM
ley's Avatar
ley
airflow sensor plugged in?
Old Apr 28, 2007 | 10:20 AM
Honder07si's Avatar
you need to makesure the O2 sensor is properly set in place and screwed in the right way
Old Apr 28, 2007 | 10:35 AM
IT GUY's Avatar
Default Re: (Honder07si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honder07si &raquo;</TD></TR><TR><TD CLASS="quote">you need to makesure the O2 sensor is properly set in place and screwed in the right way</TD></TR></TABLE>
He shouldn't be anywhere near the O2 sensor... Check your mass air sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ley &raquo;</TD></TR><TR><TD CLASS="quote">airflow sensor plugged in?</TD></TR></TABLE>
X2
Old Apr 28, 2007 | 10:44 AM
M1K3's Avatar
make sure you MAF sensor is in the right direction.
i made the exact same mistake on my aem cai install, the car would die after acouple of seconds after start up.
take it out and look for the side with a little opening in the sensor, that side needs to face the front.
GL
Old Apr 28, 2007 | 11:35 AM
Honder07si's Avatar
mass air sensor is what i ment..... thanks for the heads up
Old Apr 28, 2007 | 09:16 PM
jnuanz382's Avatar
Default Re: (M1K3)
thanks for the help guy....
pinoyboy204
May 29, 2006 01:35 PM
thelonerangers
12
Dec 17, 2005 03:37 PM
OneSickJDMBB6
15
Jun 15, 2005 07:32 PM
importnoodles
May 22, 2005 08:11 AM
OneCamIsEnough
Mar 28, 2005 08:46 AM
