GSR swap wont start!!! Please Help!
Old Apr 28, 2007 | 02:15 AM
midnitesol's Avatar
Default GSR swap wont start!!! Please Help!
I swapped a gsr into my 93 si and everything went fine until i connected my battery and realized that the 2 wires that connect to the starter were touching when it started cranking over on its own without the key. Afterwards i fixed the wires and it wont crank over it just makes some sort of sound but no cranking. Any input is greatly appreciated.
Things i tried:
1)distributor coil from obd-2 gsr distro
2)obd-2 gsr starter
3)new battery cable to starter
Still wont start
Old Apr 28, 2007 | 07:02 AM
SOHC_it_to_ya's Avatar
Default Re: GSR swap wont start!!! Please Help! (midnitesol)
No crank and a funny noise... hmm...
Maybe a starter solenoid?
Personally, if you can find another starter at a scrap yard, (for cheap) maybe try that.
Old Apr 28, 2007 | 07:22 AM
fmrprojects's Avatar
Default Re: GSR swap wont start!!! Please Help! (SOHC_it_to_ya)
check the big fuse in your fuse nder the hood, you might have blown that fuse
Old Apr 28, 2007 | 09:23 AM
midnitesol's Avatar
Default Re: GSR swap wont start!!! Please Help! (fmrprojects)
all fuses are fine. Anyone experience this before?
Old Apr 29, 2007 | 10:46 AM
midnitesol's Avatar
ok starter is workin fine and turning motor over its just not firing over, almost as if there were no spark plugs. I think its the wiring harness but not too sure. Is every wire going to the distro plugs supposed to have power or only one of them?
Old Apr 29, 2007 | 10:54 AM
BlakeJ53's Avatar
Make sure you have enough grounds, and if you have all the stock ones in place add on or two more. Make sure the valve cover is gounded.
Old Apr 29, 2007 | 11:23 AM
blackGSRcoupe94's Avatar
Default Re: GSR swap wont start!!! Please Help! (BlakeJ53)
check the ground on your valve cover and your trans to frame ground and make sure its grounded to metal and not paint.
Old Apr 29, 2007 | 02:42 PM
midnitesol's Avatar
Default Re: GSR swap wont start!!! Please Help! (blackGSRcoupe94)
F*** when i was checking my valv cover ground i realized my adj cam gear had completely moved one way cuz it wasn't tight so my timing is way off. Thanks for everyone's help it's much appreciated!
odmoht
Jun 6, 2013 04:32 PM
Nathan_volcom
Aug 26, 2012 10:17 AM
midnitesol
May 11, 2007 06:48 PM
TIRENECK
Jul 14, 2004 09:04 PM
Integra_Boi
Jul 30, 2003 12:31 PM
