have you ever dont it this way????
from this
on the ground about to come off
i know i know its a bad way of doing it but oo well
stock shocks with neuspeed springs
then to this
then to this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8CIVIC »</TD></TR><TR><TD CLASS="quote">
No, I have never aimed the strut/spring assembly at my car as I am about to fire them off.
People are way too cautious with unloading springs. Point it at a wall, put your foot on the spring and use an airtool to remove the upper nut. It'll recoil, but it's not going to shoot through the wall and bounce all over the place. The only real concern is making sure you don't let any of the washers rocket out into the great unknown.
thats the only way I do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">People are way too cautious with unloading springs. Point it at a wall, put your foot on the spring and use an airtool to remove the upper nut. It'll recoil, but it's not going to shoot through the wall and bounce all over the place. The only real concern is making sure you don't let any of the washers rocket out into the great unknown.</TD></TR></TABLE>
i just aim at a wall and keep tapping the rachet untill it springs off. never had a problem. ive heard of some idiots trying to catch it with a shirt. made a hole right through it lol.
Just wrap it in a thick blanket, and tie it down securely, and use a very long socket extension. Sounds sketchy, but is the safest method ive seen, short of actually using spring compressors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">thats how I always do it</TD></TR></TABLE>
i just use some old pants i have,, put the shock in the middle basicly where your knee would be, and unscrew with either a gun or wrench or whatever, so it stays inside the pant leg.. ( if that makes sense to you guys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">Letting it launch into a garbage can works too...make sure its a rubber one though, i used a metal one andthat shiet was loud</TD></TR></TABLE>
lol you know spring compressors are only $20 for the cheap kind that actually works with lifetime gurantee while the autozone provides em for a rental fee that gets returned if you return the tool i believe.
Larkin W.
Mar 20, 2007 02:13 PM
BiggJohnson06
Feb 15, 2006 08:43 AM
