my daily driver i just got has the hyperblink bullshit, how to remove?
but all four of the ground wires are hooked up, and none of the bulbs are out, i do not see any other wires going into the grounds or power wires
how do i remove it? 97 accord if it matters
Weren't people switching out the relay's to get the "hyperblink" too?
If it's not a burnt bulb, check the turn signals to see if the 12v switched and 12v intermittent have been switched. That's what we kids used to do back in highschool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">Are all of the bulbs standard incandescent ones, or are there LED's installed?</TD></TR></TABLE>
regular
regular
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">If it's not a burnt bulb, check the turn signals to see if the 12v switched and 12v intermittent have been switched. That's what we kids used to do back in highschool.</TD></TR></TABLE>
let me go run up the diagramn real quick
how fast does it blink? if its any faster than twice the normal rate, it probably has an aftermarket relay
all wires are in correct positions, it blinks faster than double time hard to explain haha
we have 2 97 accords, and when i pull the bulb to a turn signal it flashes so fast, but mine is flashing faster than it,
ty man im going to swap the relayreal quick good idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">ty man im going to swap the relayreal quick good idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Check your relay and your flasher.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">Weren't people switching out the relay's to get the "hyperblink" too?</TD></TR></TABLE>
^^ Ok, this was my way of saying check the relay, no thanks for me lol
</TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Check your relay and your flasher.</TD></TR></TABLE>
ef_you_again
Apr 10, 2005 12:57 PM
