DEPO Fogs Replace Bulb?
Re: DEPO Fogs Replace Bulb? (Mario.)
You can replace them, I swapped yellow Hella bulbs into mine when my normal bulbs died. Just spray the screws that hold the case together with pbblaster some before trying... mine had seized up and were a pain
1 Post
Re: DEPO Fogs Replace Bulb? (splitime)
Yeah be careful when taking off the screws in the back of the foglights. They're quite fragile even when you first get them. Once you take the back plating off, you can pull the bulb out just like you pull headlight bulbs outs. When you swap the bulbs make sure the positive and negative wires don't touch each other while bare. You'll create a short-circuit, like I did and blow the DEPO relay fuse. DEPO foglights are H3 bulb size.
Re: DEPO Fogs Replace Bulb? (Newman)
Thank you!
I found out one of the wires actually ripped today so I have to remove the whole harness and resolder it.
*fun*
Thanks a lot guys!
*fun*
Thanks a lot guys!
sohcvtec91hatch
10-23-2009 02:48 AM
