sidemarkers not blinking?
i hooked my sidemarkers up to my turn signals on my dc and they dont blink when i take turns like on my da. any help? could this be the bulb type maybe?
Re: sidemarkers not blinking?
That is the proper way to wire them up...I would double check the wires you hooked up and make sure nothing is wrong there. They should blink along with the stock turn signals.
theres 3 wires for the big bulb and 2 wires to the small bulb. first i hooked up to the small bulbs which are the parking lights then to the big bulbs which are the blinkers but still no blink. what color wires u have hooked up to the sidemarker wires?
You have one wire hooked up to ground and one to the parking light filament in the big bulb. It needs to connect to the turn signal filament on the big bulb.
Stick a multimeter lead on each terminal in the bib bulb's socket, with the other lead on ground, and see which one gets +12V when the signals flash.
