91 si b16 wont start....please help..
hello i have a 91 si w/ b16a converted to obd1 w/ hondata. problem is it cranks but dosent start. it didnt have any spark.i had my laptop hooked up and the code for ignition output signal came on, i checked the wires and grounds and timing. i just bought a brand new distrubitor and still nothing, but now i have spark...
thanks for the help
thanks for the help
Make sure your getting fuel. Listen for a click sound under the left side of the dash when you turn on the key. it should click then click again after 3 seconds. if that works then your getting fuel. try that to start off with. Usually the main fuel relay goes out.
ok i herd the click, and i know iam getting fuel becuse i loosened the 2 bolts on the fuel pressure regulater and gas started to come out, and i pulled the plugs and they had fuel on um and i could smell it, i know it has spark
ok i got it to start..i ordered the distributor from distributor king w/ there conversion, to obd0 plugs, and they had the pins crossed.now my problem is there is a big loss of power, when iam flooring it, it bogs and it takes a long time to get going, no codes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civhatch90 »</TD></TR><TR><TD CLASS="quote">i had a problem with my car bogging just recently and it ended up being that the dizzy needed a new cap and rotor, when you got that one new did you change that?</TD></TR></TABLE>
no i just bolted it on, you think i should switch over the rotor from the old dizzy? thanks
Are there any cel codes? I like your username, i have vw myself, maybe we should hit the track 1 day lol jk. sprark plugs, wires, dizzy somewhere along those lines is the culprit.
it ran fine before the distrubitor went out, so i replaced it and thats it and now it runs like crap, when i ake off the accelleration sucks, it takes a while to start going, and i have no power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">check to see if the timing has slipped...low/no compression will cause fast cranking...</TD></TR></TABLE>
yep thats what it was, timing sliped 1 tooth on the intake cam.
DehKillaBeezz
Feb 13, 2011 12:38 PM
DukeVonDANK
Jun 2, 2005 11:28 AM
indy_parrothead
May 5, 2003 11:15 AM
