When removing and re-installing axle shafts,do I need to change anything???
Old Apr 26, 2007 | 07:08 PM
Xemu's Avatar
Default When removing and re-installing axle shafts,do I need to change anything???
Removed the axle shafts from 4 speed slush box and want to install in Si tranny.Everything looks good and clean is there anything I should now or do?? I gotta het a Helms!!!! Thanks
Old Apr 26, 2007 | 07:25 PM
fireant's Avatar
Default Re: When removing and re-installing axle shafts,do I need to change anything??? (Xemu)
New Axle nuts are good if you fubar'd the old ones. If the trans oil starts dripping, you'll need new axle seals. the 32mm axle nut socket is helpful for tapping the new seals in.
Old Apr 26, 2007 | 07:32 PM
Xemu's Avatar
Default Re: When removing and re-installing axle shafts,do I need to change anything??? (fireant)
All good info,Thanks Dude. I actually dropped the whole front end and slid the shafts out of the tranny no removing of any bolts but I did lose some tranny fluid so I will replace the seals,thanks,anything else!!
jmurphy
17
Apr 5, 2011 01:19 PM
minvi
Aug 9, 2010 04:17 AM
clampjaw25
May 21, 2007 01:56 PM
See Are X
Oct 21, 2003 09:23 PM
