Swapped now no cat converter
Old Apr 26, 2007 | 05:48 PM
994door's Avatar
Default Swapped now no cat converter
i have a 99 civic with a gsr that i kept obd2. the old motor had the cat attached to the manifold so i dont have one under the car. i have a new cat converter for a 91 integra... would that be fine for the comp or does it have to be for a gsr? also do the o2 simulators really work? thanks alot.
Old Apr 27, 2007 | 07:03 AM
994door's Avatar
Default Re: Swapped now no cat converter (994door)
bump
Old Apr 27, 2007 | 07:18 AM
Malakai's Avatar
bump, would like to know about the simulators too. I will be doing an obd2 ls swap and leaving out the cat.
Old Apr 27, 2007 | 07:41 AM
pdiggitydogg's Avatar
Just weld an o2 bung on the cat, after the filament
You may need to mess around with flange orientation...I dont know.
You are much, much better off with a cat though...without one they stink like *** and are ridiculously louder than you may think.
(my beater doesnt have a cat and its probably one of the worst things about the car)
I highly suggest you get one, if not the DA cat, then a new one.
Some simulators work...many do not
Old Apr 27, 2007 | 07:49 AM
994door's Avatar
Default Re: (pdiggitydogg)
thanks, i guess i'll just weld a bung on...
Modified by 994door at 2:15 PM 4/27/2007
Old Apr 30, 2007 | 04:33 PM
994door's Avatar
Default Re: (994door)
does a jdm obd2 ecu need the second o2 sensor?
Old May 1, 2007 | 04:35 PM
994door's Avatar
bump
Old May 1, 2007 | 04:47 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 994door &raquo;</TD></TR><TR><TD CLASS="quote">does a jdm obd2 ecu need the second o2 sensor?</TD></TR></TABLE>
Mine looks for it...all you have to do is wrap the o2 sensor in aluminum foil and zip tie it to your shift linkage (the part that doesnt move) and you are all set no more cell...kind of ghetto but it works as a quick fix.
Old May 3, 2007 | 07:32 AM
Malakai's Avatar
Default Re: (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
does this really work? good enough fix for me.
Old May 3, 2007 | 07:58 AM
B16b-EJ8's Avatar
Default Re: (Malakai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malakai &raquo;</TD></TR><TR><TD CLASS="quote">
does this really work? good enough fix for me.</TD></TR></TABLE>
Yes it woorks, i have been driving it around for about 6 months that way no cell...Idle is a little off but i think that is because of my IACV
Old May 3, 2007 | 08:20 AM
97Ej6mike's Avatar
Blox Makes a Screw-in gap insert, that gaps the O2 sensor farther from the exhaust pipe, confusing it into thinking its a clean burn, so the 2nd O2sensor wont throw a CEL in the absense of a CAT.
White GSR
Northern California (Sales)
Mar 11, 2010 09:34 PM
error
Sep 9, 2006 09:52 PM
no2unenolife
Oct 31, 2005 03:08 PM
adobospoon
Oct 30, 2005 09:26 PM
95ex5speed
Oct 20, 2004 08:52 AM
