Ticking noise? Injectors?
Old Apr 26, 2007 | 11:12 AM
boomersz's Avatar
Default Ticking noise? Injectors?
edit: Well I think it went away I guess, but I got another really loud noise. It's from the IM area, kinda sounds like its below it too. Sounds like a loose bolt or something rattling around, its on and off.
car seems to be running fine and it's a gsr swap..
Modified by DrZoidberg at 7:39 PM 4/26/2007
Old Apr 26, 2007 | 11:23 AM
dpaton's Avatar
Default Re: Ticking noise? Injectors? (DrZoidberg)
Could be valve lash too. Probably the injectors though.
Old Apr 26, 2007 | 11:25 AM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (dpaton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpaton &raquo;</TD></TR><TR><TD CLASS="quote">Could be valve lash too. Probably the injectors though.</TD></TR></TABLE>
Valve adjustment? What could cause the injectors to make noise? It just randomly started doing it one night.
Old Apr 26, 2007 | 12:11 PM
Perfectionist's Avatar
You could use a piece of plastic tubing and hold one end to your ear and move the other end to the injector or head area where you think the noise is coming from. It's kind of like using a stethescope.
Old Apr 26, 2007 | 01:06 PM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (Perfectionist)
i guess i can try that haha
Old Apr 26, 2007 | 01:33 PM
Slamminmofo2k7's Avatar
PCV valve makes a ticking type of sound also.. I'm not sure about other years but I know the 92-95's have the PCV valve right below the injector area.
Old Apr 26, 2007 | 01:46 PM
EL Vap133's Avatar
What engine do you have? On my B16, I had a smiliar noise and it turned out to be the Los Motion Assemblies.
Old Apr 26, 2007 | 02:06 PM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slamminmofo2k7 &raquo;</TD></TR><TR><TD CLASS="quote">PCV valve makes a ticking type of sound also.. I'm not sure about other years but I know the 92-95's have the PCV valve right below the injector area.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">What engine do you have? On my B16, I had a smiliar noise and it turned out to be the Los Motion Assemblies. </TD></TR></TABLE>
Old Apr 26, 2007 | 02:26 PM
dpaton's Avatar
Definitely time for the mechanic's stethoscope. Rattling like that is a bad sign.
Old Apr 26, 2007 | 04:32 PM
boomersz's Avatar
anyone??
Old Apr 26, 2007 | 04:38 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrZoidberg &raquo;</TD></TR><TR><TD CLASS="quote">anyone??</TD></TR></TABLE>
i guess i would say it's normal? i have a B16A and mine does the same thing.
car runs strong and smooth, and i just did a valve adjustment alittle under 2 months ago so i know it's not that.
Old Apr 26, 2007 | 04:39 PM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
car runs strong and smooth, and i just did a valve adjustment alittle under 2 months ago so i know it's not that.</TD></TR></TABLE>
The injector noise is gone...i'll edit the first post.
Old Apr 26, 2007 | 10:02 PM
boomersz's Avatar
Old Apr 26, 2007 | 10:51 PM
aarethas's Avatar
is your noise at idle? can you rev the engine and it gets louder/faster? when driving in a tunnel/near a median, can you hear the sound bounce off while under load?
two things I've learned through all my hondas.......they all have noisy valves and they all have noisy injectors. the worst was my S2000.
if it is a random noise and it doesnt seem to affect drivability, try using wd-40 around metal moving parts/bolts/pullies. See if the noise goes away. I had a random tinny noise pop up in my '98 CL that ended up being a pulley bolt that wanted attention.
Old Apr 27, 2007 | 05:10 AM
boomersz's Avatar
Default Re: Ticking noise? Injectors? (aarethas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarethas &raquo;</TD></TR><TR><TD CLASS="quote">is your noise at idle? can you rev the engine and it gets louder/faster? when driving in a tunnel/near a median, can you hear the sound bounce off while under load?
if it is a random noise and it doesnt seem to affect drivability, try using wd-40 around metal moving parts/bolts/pullies. See if the noise goes away. I had a random tinny noise pop up in my '98 CL that ended up being a pulley bolt that wanted attention.</TD></TR></TABLE>
i can hear it at idle and while driving. it's on/off noise
Modified by DrZoidberg at 8:57 AM 4/27/2007
Old Apr 27, 2007 | 07:32 AM
boomersz's Avatar
bump
Old Apr 27, 2007 | 07:56 AM
ifIexplode's Avatar
Heat sheild maybe?
Old Apr 27, 2007 | 08:00 AM
boomersz's Avatar
Default Re: (ifIexplode)
nah its from like the intake mani area. i checked everything that i could if it was loose or something
Old Apr 27, 2007 | 10:35 AM
aarethas's Avatar
Default Re: (DrZoidberg)
when was the last time you had a valve adjustment? can you hear the noise if you get under the car and put your ear near the oil pan?
I'm not too familiar with gsr motors, but in general if a honda was making the noise youre saying......first I would do a valve adjustment, check pcv+egr valves, then I would assume it's the timing tensioner, then after that, not sure but I would start looking for holes in the hardware.
Old Apr 27, 2007 | 10:41 AM
boomersz's Avatar
Default Re: (aarethas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarethas &raquo;</TD></TR><TR><TD CLASS="quote">when was the last time you had a valve adjustment? can you hear the noise if you get under the car and put your ear near the oil pan?
I'm not too familiar with gsr motors, but in general if a honda was making the noise youre saying......first I would do a valve adjustment, check pcv+egr valves, then I would assume it's the timing tensioner, then after that, not sure but I would start looking for holes in the hardware.</TD></TR></TABLE>
never did one since i did the swap. im going to my friend at honda to put it on the lift after hours and ill try to find out.
Old Apr 27, 2007 | 01:32 PM
boomersz's Avatar
anyone else?
Old Apr 27, 2007 | 03:32 PM
boomersz's Avatar
checked under and around, cant find anything
Old Apr 27, 2007 | 06:39 PM
boomersz's Avatar
help
Old Apr 28, 2007 | 10:43 AM
boomersz's Avatar
kte324
Oct 6, 2008 08:17 PM
boomersz
Apr 28, 2007 04:19 PM
projectac
Jul 29, 2005 07:24 AM
SleepnCiViC
Feb 14, 2004 01:49 AM
Luke
Feb 17, 2002 09:26 AM
