need help Ek- to - 99-00 si swap error p0113
hi guys i just recently did a 99-00 hond civic si swap into a EK and ever scince the swap ive been getting this p0113 code and i dont know how to clear it. i bought the motor from Hap basically a junk yard but does anyone know how to fix this problem or should i have a professional do it and if so how much would it cost.?
also does any have the 0bd2 honda civic si wiring diagram for the ecu i need it to wire in my second 02 sensor thanks
If it's an IAT sensor code then unless your wiring is fucked up, it's the IAT.
Are you sure the one you replaced it with works?
And by resetting the ecu, I mean take it out for about 10 minutes and then put it back in.
here the thing the only difference with my b16a2 from a bone stock b16a2 is that i have a aftermarket Skunk2 intake mainifold and i just looked in the manual and my iat sensor isnt in the same place that it should be perhap i change wrong sensor?
ok sorry to trouble you guys just found out today by going up to the place where i bought the motor and they brought another Si wireing harness and we found out that the owner previously b4 me had cut out the iat sensor wire thus fourth giving me the code thanks btw
clevisR6
Aug 10, 2005 02:20 PM
