Installing a tach in civic?
Old Apr 26, 2007 | 08:08 AM
EJ8 GSR-T's Avatar
Default Installing a tach in civic?
When installing and aftermarket tach is there a wire in the cluster you can tap into or do you have to go to the distributor? If you do which wire is it? (98 civic ex)
Old Apr 26, 2007 | 08:52 AM
fitbmx86's Avatar
Default Re: Installing a tach in civic? (EJ8 GSR-T)
theres a wire in the cluster, if you have a ex you should already have one in the cluster, so just find that wire and splice into it. i did it in my 95 dx it was a green wire i belive but just look up the wiring for your car its easy.
Old Apr 26, 2007 | 08:59 AM
Eran's Avatar
HT White Ops
why do you need a second tachometer?
Old Apr 26, 2007 | 09:01 AM
HCJDM1's Avatar
Default Re: (Eran)
i dono .. myabe he wants a light to go *ping* *flash* and blind him while hes driving .. who knows
deadline's Avatar
it will most likely get your car broken into with that big-azz thing popping out....
Old Apr 26, 2007 | 09:10 AM
STI champstar's Avatar
Default Re: (deadline)
The blue wire on the driver side behind the strut tower that leads to nothing. Atleast on 92-95 civics.
DeeJaaY209
Sep 19, 2013 01:27 AM
gearhead16
Feb 18, 2007 11:39 AM
civiccrazy93
Jan 5, 2005 10:33 AM
joecivic93
Jan 6, 2004 10:07 PM
MIdoriEK
Apr 3, 2002 11:46 PM
